tranny bolt up???????
Old Apr 6, 2003 | 04:03 AM
zcar8585's Avatar
sorry this is off the wall i looked but couldnt find it and i figured you guys would know
will a turbo 400 out of an 84 chev with a diesel fit a 73 olds 455 rocket
Old Apr 7, 2003 | 10:46 AM
MDv6man's Avatar
Car: 1983, 1986
Engine: 2.8 2bbl, 2.8 MPFI
Transmission: 200C 3 speed, 700R4
Axle/Gears: 3.08, 3.42
Nope. the 455 has a different bolt pattern. You will need an adapter.
Old Apr 8, 2003 | 05:36 PM
unknown_host's Avatar
Car: 1989 Iroc Z L98
I know Pontiac blocks use chevy transmissions, do olds blocks not?
Old Apr 8, 2003 | 06:48 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Pontiac blocks do not use Chevy tranmissions. BOP (Buick Olds Pontiac) ones are named that for good reason.
Old Apr 8, 2003 | 06:58 PM
My friend has a pontiac 350 in his 72 Ventura and runs a turbo 350. I thought the 350 and 455 were based on the same block?
Old Apr 8, 2003 | 07:18 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
No.
There are Chevy and BOP versions of both of those transmissions. Identical guts, different bolt pattern on the case.
Old Apr 8, 2003 | 07:42 PM
No.
I just called my friend and it all makes sense now. he has a universal bellhousing turbo 350, so that is why he is using a turbo 350 that bolts up to either or.
Old Apr 9, 2003 | 09:10 PM
zcar8585's Avatar
thanx for all ur help
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
GouldyGTR
Sep 7, 2015 09:05 PM
Stryker412
Sep 7, 2015 09:11 AM
Formula_88AE
Sep 3, 2015 01:47 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
