3.1L v6 to L98 swap
Old Apr 19, 2003 | 07:32 PM
krazycracka55's Avatar
Car: 92 RS 25th Anniversary
Engine: 3.1
3.1L v6 to L98 swap
how hard is this and how much am i looking at spending?
thnx
Old Apr 20, 2003 | 01:13 AM
Quick_Trans_Am's Avatar
Car: 1985 Pontiac Trans Am
Engine: 355 with stuffs.
Axle/Gears: 4.10 Posi
It all depends on what you want. It can be hard if you don't know what you are doing. If you are new to engine swaps, GET A V8 DONOR CAR. If you know what you are doing and what all is involved, then go to a junkyard and buy a COMPLETE L98 setup. Basics you will need:
L98 (obviously)
V8 transmission (V6 version will NOT bolt up)
V8 Fuel pump
V8 Motor mounts
L98 Engine wiring harness.
7730 ECM and PROM (your 3.1 already has the 7730 ECM, but not the right PROM)
You are looking at anywhere from $1k to 2k to do this right, buying all the parts. If you can find a wrecked donor car with a L98 in it for a few hundred, BUY IT.
I know I left some stuff out here, so try running a search to see what you can turn up. Good luck.
92projectcamaro
Aug 6, 2015 01:20 PM
zer0321
Jun 15, 2003 09:28 AM
Drew
Sep 4, 2001 11:49 PM
Monkie
Dec 31, 2000 11:27 PM
Cricket92RS
Dec 20, 2000 01:45 PM
