383 Stroker--Can I Use TPI?
Old May 4, 2003 | 08:23 PM
blue86z28's Avatar
1986 Camaro Z28 LB9 Auto
Hi--I am going to buy a used 350 engine, converting to 383 Stroker, and i want to know if i can use the TPI setup off my 305 LB9 on it....i know i will definatley have to port match it....
Old May 4, 2003 | 08:25 PM
wm_sorg's Avatar
Car: 1991 Formula Firebird
Engine: 2001 LS1 Modded
Transmission: 2001 4L60E Yank SS3600 TC
You will have to do a lot to get it to feed a 383. I would get a super ram.
Old May 4, 2003 | 09:43 PM
87WS6's Avatar
Car: 1992 Formula Firebird
Engine: 305CID (LB9)
Transmission: World Class T5
Axle/Gears: 10-bolt, 4.10 gears
You could but it won't be optimal. A TPI system barely feeds a 305 much less a 383. Get a Miniram, Superram or Stealthram.
I am partial to the Miniram myself.
toronto formula
Nov 10, 2015 06:17 AM
bdads
Aug 24, 2015 06:01 PM
86White_T/A305
Aug 17, 2015 12:16 AM
85Iroc-Z
Aug 13, 2015 01:58 AM
Sanjay
Aug 12, 2015 03:41 PM
