2.8-5.7 computer stuff..no expert here
I'm planning on a donor car for the 2.8mpfi- 5.7tpi its an easy swap so people tell me but what do i do about the computer i have no idea about the computers none..exept they **** me off. so what do i do just switch the computeres and if so how hard is that?? and what about the fuel lines just bigger fuel pump?? plz help me and advice would be really helpfull..
Car: 89rs (previous 2.8)
Engine: 406
Transmission: 700r4 (for now)
You use mechanical gauges.....you use a adjustable fuel pressure regulator with your stock pump...your power assist vacuum line connects to the carb...leave the computer in and you can wire in a TC lock-up switch pretty easy...a carb swap is much easier than the TPI..IMO.
The stock amp gauge will work...the speedo will work...the tach will need replaced either way..its a v-6 tach wont work...you have a v-8 tranny right?
Car: 1985 Pontiac Trans Am
Engine: 355 with stuffs.
Axle/Gears: 4.10 Posi
If you're still interested in using the comp and TPI, the computers will just unplug and switch. What year is the donor car, is it similar to the one you have?
Car: 4
Engine: 6
Transmission: 5
AFAIK the computer itself is the same, in some variations of 2.8s and 350s; the ECM everybody tries to get for their speed-density TPI cars for example, is the 7730, which is in like every Buick 3800 equipped car there is, like Century, Cutlass, etc. etc.
The computer doesn't really care how many cylinders there are. It gets one pulse for each one from the distributor. All you have to do is tel it what to do with that pulse (PROM programming).
Yes you will need a V8 transmission.
The gauges also do not care about how many cylinders there are; except for 2 details. The tach is different (3 pulses from the dist per crank rev from a 6-cyl, 4 pulses per crank rev from a V8); and the 6-cyl oil pressure gauge is 80 psi full scale, the V8 one is 60 psi full scale.
rs_z28_vert
Sep 30, 2015 09:47 PM
Damon
Sep 26, 2015 04:29 PM
