383 swap in cali
Old Jun 6, 2003 | 12:37 AM
PHAT89TA's Avatar
Car: 02 ws-6
Engine: 5.7 liter
Transmission: t56
383 swap in cali
im planning on swapping out my 305 tpi to a 383. I've been searching through the internet and I have my eyes on this engine. My question is that will this engine will pass emissions with the cam it comes with. I also will keep all my emissions and maybe my tpi system and modify it. This is the engine im thinking of buying but i jsut want to to how u guys if this engine will be able to pass smog. heres the website to it http://www.golensengineservice.com/
Chevy
383 CI TPI Stroker
405 HP
Street/Strip
Long Block
$3,999.00
Block:
Thermally cleaned and Stainless-Steel Shot. Inspected by MPI process. Bored, honed with torque-plates and pressure washed. Clevite cam bearings and pioneer brass freeze plugs installed.
Crank:
Eagle Nodule-Iron
Rods:
Eagle Forged 5140 I-Beam
Pistons:
Keith Black HyperEutectic
Rings:
Speed-Pro Plasma-Moly
Bearings:
Clevite Main and Rod Bearings
Core Plugs:
Brass Pioneer Core Plugs
Lifters:
Comp Cams Hydraulic
Pushrods:
Comp Cams
Rocker Arms:
Comp Cams Magnum Roller Tip
Timing Set:
Cloyes True-Roller
Timing Cover:
New Factory
Oil Delivery:
Melling High Volume Pump, Pickup Tube and HD Drive
Oil Pan:
New Factory 6-Quart
Harmonic Balancer:
Pioneer Performance
Gasket Set:
Fel-Pro Performance
Head Bolts:
SBI Performance
Heads:
Model
Edelbrock Performer RPM
Type
Aluminum
Combustion Chamber
70 CC
Intake Runner
170 CC
Intake Valves
Manley Stainless Steel 2.02"
Exhaust Valves
Manley Stainless Steel 1.60"
Compression Ratio
10.0:1
Cam:
Manufacturer
Comp Cams
Operating Range
1800 - 5800 RPM
Idle Quality
Good
Duration
Intake 222° @ .050"
Exhaust 226° @ .050"
Lift
Intake 0.464"
Exhaust 0.464"
Lobe Seperation
114°
Old Jun 6, 2003 | 04:49 AM
85TPI400's Avatar
First thing to cosider is that the performer RPM heads DO NOT have EGR provisions so you would need to do the same thing people are doing with vortec or ZZ4 (corvette) heads and using a similar to Corvette style EGR tube that goes from your exhaust to the intake. You would need an aftermarket or corvette baseplate to make this work. Otherwise I am guessing it might pass. The camshaft they are using is the same one I am hopeing to get through smog with on my superrammed 400 engine.
Although it sounds like a decent engine for the price, I would think for the overall cost you could find a 350 roller block, and build, or have built a rollercammed 383 for less money.
Good Luck!
Old Jun 6, 2003 | 09:05 AM
PHAT89TA's Avatar
Car: 02 ws-6
Engine: 5.7 liter
Transmission: t56
thanks 85tpi400. People with ls1's have been passing the sniffer test with a bigger cam so i don't see y not this cam will pass. You know any place that i can find a 350 roller block for a good $$$ and what do u recommend on a stroker kit.
Old Jun 6, 2003 | 09:17 AM
PHAT89TA's Avatar
Car: 02 ws-6
Engine: 5.7 liter
Transmission: t56
they also have just the short block for sale also but its around 2k's
Old Jun 10, 2003 | 10:40 AM
87WS6's Avatar
Car: 1992 Formula Firebird
Engine: 305CID (LB9)
Transmission: World Class T5
Axle/Gears: 10-bolt, 4.10 gears
I have thought about using that same engine. What if I used a TPIS miniram? It has no provisions for EGR either. How would I go about dealing with the EGR? Or do I just leave it all out.
Old Jun 10, 2003 | 06:39 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
That's because they were designed that way. Your's wasn't. Unless you build yours as an LS1 with all of the equipment an LS1 comes with, you won't pass muster.
onefreakz
May 14, 2018 12:15 PM
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
Cameeeero
Sep 18, 2015 04:00 PM
lt1z350
Aug 28, 2015 05:57 AM
sreZ28
Aug 14, 2015 07:48 PM
