Top End
Old Jun 16, 2003 | 12:38 PM
Fade07W's Avatar
Top End
So the next 350 is going into the Trans Am. Short Block is complete, 9 to 1 compression and I am hoping to run a comp cams 268h. So I am wondering what type of head/valve train I should be running with this combo to hit 325+ horse. No expensive aluminum goodies, sorry guys can't do AFR's . So I am pretty much open to any suggestions, hoping the top end will come out for less than a grand but lemme hear some opinions.
Old Jun 16, 2003 | 01:47 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
What type of induction?
You pick your cam to match other things that you use, you don't build a motor around a cam.
wm_sorg's Avatar
Car: 1991 Formula Firebird
Engine: 2001 LS1 Modded
Transmission: 2001 4L60E Yank SS3600 TC
How about the L98 aluminium heads that came on the vette engine. I do not know flow numbers but they will save you some weight at 40 lbs least.
Old Jun 16, 2003 | 03:49 PM
Fade07W's Avatar
I already have the cam so it makes sense that if I want to hit the mid 300 horse range. So what type of intake and heads would flow best with that type of camshaft yeilding the most power. Keeping in mind that everything will remain hydraulic. The aluminum L98 heads seem like a good choice or perhaps even vortecs but with these heads would porting be necessary and stock how well will they flow at 6000 rpm? Also what type of intake would be best?
Old Jun 16, 2003 | 09:35 PM
wm_sorg's Avatar
I would do porting regardless of what heads you end up with. Since you have them off it just makes good sense. If you are looking to make power up top you need a mini ram or LT1 style intake.
As far as cams go there are several options available. I would decide on the heads first then select the cam. Remember bigger cams do not nessicarily make you go faster.
customblackbird
Aug 15, 2021 10:16 PM
SiCkRs
Members Camaros
32
Jul 1, 2018 04:53 AM
Azrael91966669
25
Jun 20, 2017 04:04 AM
xxx3man`
Sep 23, 2015 10:37 PM
