LT1 T56 on LS1 engine
Car: 1987 Trans Am
Engine: Lt1
If I remember correctly, the earlier trans(93-97) will not work on an LS1. Check here http://www.sallee-chevrolet.com/Chev...ons/gmt56.html
According to the last few lines, the flywheel, clutch assembly, etc. will not work on your motor. The slave cylinder on the earlier trans is a push type and the later is a pull(traditional) type if memory serves me correctly.
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
Re: LT1 T56 on LS1 engine
Originally posted by Clint E.
Hey, Can I use my LT1 T56, flywheel, belhousing and clutch on a LS1 engine?
nope... input shaft on the tranny is diffrent, bellhousing bolt pattern is diffrent, clutch is diffrent...
1992 Trans Am
Aug 8, 2015 08:16 PM
