C100 and the LT1
Old 07-16-2003, 11:42 AM
Corry's Avatar
Car: 1987 Trans Am
Axle/Gears: 10 Bolt SLP Torsen, 3.73 ratio
C100 and the LT1
There is a lot of information out there on this, however, no one said what they actually did.
What I am guessing is going on, after staring at diagrams for a while is that the C100 connector is on the thirdgen, and there is a connector off the harness that goes to an under-hood fusebox, and that rather than getting that fusebox, people are instead hacking the lines off the LT1 harness into the C100. Am I right? Do I not need the underhood fusebox?
Corry
Old 07-16-2003, 12:07 PM
Trans Am#5's Avatar
Car: 1987 Trans Am
Engine: Lt1
I hacked everything into it and eliminated the under hood fuse box. I do have some fuses though as I used a Painless harness.
Old 07-16-2003, 12:08 PM
Corry's Avatar
Car: 1987 Trans Am
do I need any extra fuses, or will the motor run just by splicing into the C100 connector?
Old 07-16-2003, 12:13 PM
Trans Am#5's Avatar
Car: 1987 Trans Am
Engine: Lt1
The c100 connector has all the connections for the accesories and a few of the gauges. The only one necessary for the car to run here is the purple cranking wire that must go down to the starter solenoid. All your gauges will be here except for fuel and speedo.
Old 07-16-2003, 12:14 PM
Corry's Avatar
Car: 1987 Trans Am
I was concerned about fuses for the injectors/etc
Old 07-16-2003, 12:20 PM
Trans Am#5's Avatar
Car: 1987 Trans Am
Engine: Lt1
Those were part of my Painless harness but you'll have to use the original fuse box for those.
88SS6SPEED
11-11-2015 07:05 AM
thunder57
11-07-2015 02:28 PM
L0tuS
10-04-2015 08:07 AM
WejaZ28
10-03-2015 07:38 PM
Jackrabbit501
09-02-2015 09:14 PM
Quick Reply: C100 and the LT1
