305 / 350 TPI straight swap?
Old Jul 27, 2003 | 12:32 AM
batmanta01's Avatar
Car: 91 GTA, 95 T/A, 80 FIREBIRD
Engine: 350, 350, 305
Transmission: 700R4, T-56, TURBO 350
I have a 1990 Formula 350 and a 1991 Formula 305. (5speed tranny) I want to swap the engines, and sell the 90. Is there anything I need besides the swap of engines and ecm's, or do I need to have a custom chip made? I'm not doing the swap myself, I have a friend who has done a bunch, (mostly 70's stuff) just not the tuned port variety. Thanx in advance for any and all responses.
Old Jul 27, 2003 | 12:49 PM
bad_ta_05's Avatar
Car: 85 trans am
Engine: 79 4 bolt 350
everything should fit right up, they are both small blocks so it will be fine. if they are both tpi then u will have to swap over the ecm and stuff but it should be fine, you have all the parts you need if u have 2 cars.
Old Jul 30, 2003 | 08:09 PM
87WS6's Avatar
Car: 1992 Formula Firebird
Engine: 305CID (LB9)
Transmission: World Class T5
Axle/Gears: 10-bolt, 4.10 gears
Actually you just need the knock sensor, the injectors and the chip. I think the ECU is the same. I could be wrong on that last part. But 305-350TPI's are about as easy as an engine swap gets on these cars. Also you will need the flywheel for the 350. The 350 will be in a car with an auto to start with.
BlueIroc-Z
Jun 9, 2019 03:22 AM
Fast355
Dec 2, 2016 06:33 PM
wruiz
Aug 13, 2015 09:07 PM
st.evel07
Aug 13, 2015 06:15 PM
gta power
Aug 13, 2015 06:15 AM
