where to lift engine
Old Aug 3, 2003 | 09:53 PM
kbcattle's Avatar
I have never pulled a TPI Motor or any fuel injected motor out of a car before so I was wondering where do you pull it from to get it out of the car? Can you use a engine lift plate like you would bolt to the intake on a carbed engine or do you need a special plate or do you hook chains somewhere? The engine I want to pull is a 350 TPI out of a 88 formula and I would like to get the trans out still attached to the motor.
Old Aug 3, 2003 | 10:08 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Get a chain with the proper weight rating first. Then, put a bolt through a link in the chain and put in in the accessory holes in the heads. I used the front of the drivers side head and back of the passenger side head.
LT1Formula
20
Nov 14, 2015 12:02 AM
gta90
Sep 15, 2015 04:00 PM
NWAsonoma
Aug 18, 2015 05:45 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
anesthes
Aug 8, 2015 09:37 PM
