will my t56(1996 TA) bolt up to a LS1
Old Aug 11, 2003 | 12:00 AM
BigMInstalls's Avatar
I heard somewhere that the earlier t56's won't bolt up to the newer LS1's? Is this true. Considering the LS1 swap and this would be a the deciding factor. Thanks in advance for the help
Old Aug 11, 2003 | 12:06 AM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
T-56
You are right, it won't bolt up.
Old Aug 11, 2003 | 12:08 AM
what would I have to do to use this tranny, buy a diff bell housing for it? or just sell it and buy a LS1/t56 set up??
Old Aug 11, 2003 | 04:40 PM
wm_sorg's Avatar
Car: 1991 Formula Firebird
Engine: 2001 LS1 Modded
Transmission: 2001 4L60E Yank SS3600 TC
As I recall there is a difference in the input shaft length. Save yourself the headaches and get the LS1 T56.
Old Aug 12, 2003 | 12:02 PM
PETE's Avatar
Car: 1989 TTA #1240
Engine: 3.8 SFI turbo
Transmission: 2004r
Bellhousing is different, input shaft is different, throwout bearing and actuator is different. Thetre may be more
1984HO
Mar 19, 2021 11:59 AM
84z96L31vortec
Aug 20, 2017 12:16 AM
smokingss
LSX and LTX Parts
Mar 3, 2016 07:40 PM
86White_T/A305
Aug 17, 2015 12:16 AM
