Engine Brackets for TPI to Carb Swap
Old Aug 17, 2003 | 12:00 AM
TOXIC-Z's Avatar
Car: 1988 IROC
Engine: 383
Transmission: 700R-4
Allright I'm deleting everything I can off my IROC to clean up the engine bay for this swap...AC, Power steering, Smog pump, etc. I'm looking to see what brackets to get to route the belt for my motor. I've seen the alternator mounted on the passenger side and wondered how to do that because mine hits my valve cover on the driver side. Anyone know where to get brackets to do this and belt part numbers. I'm not sure what to do about the blet tensioner or can I go with another setup. I thought some of the magazine motors looked like their alternator brakets had turnbuckles on them for adjustig belt tension. Is that so? Thanks in advance
Old Aug 22, 2003 | 02:55 PM
70GTO's Avatar
Car: 89 Iroc Z
Engine: Carburated 427 Smallblock
Transmission: 400 Turbo
After you determine what accessories you are going to use you need to get ahold of March pulleys or Zoops,. They both supply pulley systems for pretty much any application or set-up. They make real nice systems 'V belt or serpentine with the turn buckels like you mentioned, however they are pretty pricey. Sorry I can't get you a link for them, but you should be able to find them with any search engine easily.
Hope this helps, Bruce
Old Aug 22, 2003 | 05:09 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
Sounds like the crank, water, and alt pullies and alt bracket from an 86 ~ should work for you, its a mini serp setup.
Old Aug 22, 2003 | 05:54 PM
onebinky's Avatar
Exactly right. That's how it's set up on my 87 IROC currently
Old Aug 23, 2003 | 07:40 AM
TOXIC-Z's Avatar
Car: 1988 IROC
Engine: 383
cool anyone know how much?
Old Aug 23, 2003 | 10:04 PM
onebinky's Avatar
Eh, probably pretty cheap. Just go pick them from a boneyard
Old Aug 24, 2003 | 07:40 AM
TOXIC-Z's Avatar
Car: 1988 IROC
Engine: 383
Is that from an 86 camaro?
Old Aug 24, 2003 | 11:22 AM
onebinky's Avatar
I know for sure 85-87 will work, I don't know about other years though. I think they started using the serpentine setup in 89 or 90.
midge54
Dec 27, 2019 04:14 PM
theshackle
Mar 5, 2017 06:37 PM
midge54
Jan 29, 2017 07:00 PM
Fast355
Dec 2, 2016 06:33 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
