Good deal on LS1 and 6spd?
Old Aug 22, 2003 | 08:56 PM
91305z's Avatar
Just figured I'd post this if anyone was interested.
http://page.auctions.shopping.yahoo....9?aucview=0x23
Old Aug 23, 2003 | 12:19 AM
Longer91Cam's Avatar
Car: 91 RS
Engine: 305 TBI
Yes i would like to know if this is a good deal. You can buy it at $1900. Also will this just drop in in place of a 305 tbi without any extra parts since it comes with everything? If not then what has to be done for it to work?
Old Aug 23, 2003 | 01:23 PM
BrianI's Avatar
That is a sweet deal on an LS1/6speed combo!
Old Aug 23, 2003 | 05:14 PM
Car: 91 RS
Engine: 305 TBI
Now does anyone have any ideas on t he question that i asked before? I would like to buy it but i need to know if it will be expensive to have installed and also what other parts i will need to make it work in place of my 305 tbi. Please help
Old Aug 23, 2003 | 05:38 PM
BADBIRD009's Avatar
oh my ***, that is a very very sweet deal. that 6 speed alone is worth 1900, and it only has 573 miles! sphon has a custom crossmember and torque arm for a 6 speed swap. you will need that.
you need to jump on that deal Longer91Cam!
Old Aug 23, 2003 | 05:46 PM
Car: 91 RS
Engine: 305 TBI
Yeah but what else do i need to get for it to work? What things will i need to change on my fuel system and such? Also does it look like that engine comes with everything i need already? Like the alternator and stuff like that? Thanks
Old Aug 23, 2003 | 06:00 PM
BADBIRD009's Avatar
im not sure of everything you will need, but i am sure of the cross memer and torque arm.
your motor mounts are probably gonna be different also.
your feul pump definatly wont work. you will need one that has more pressure. your TBI only needs like 15psi or so but an ls1 will need at least 40 psi.
if you have an automatic you will need a master clutch cylinder and a cluth/break pedal assembly, which you can get from a salvaged third gen.
Old Aug 23, 2003 | 06:02 PM
Car: 91 RS
Engine: 305 TBI
I have a manual transmission already so that wont be a problem. I started another post so i can get more help. THanks
Old Aug 23, 2003 | 06:05 PM
BADBIRD009's Avatar
here are the motor mounts and cross member. http://www.thirdgenresource.com/inc/...l?v=1&pid=2047
Old Aug 23, 2003 | 07:31 PM
SweetS10v8's Avatar
Car: '89 Formula 350 & '86 Z28
Engine: L98 & 355ci
Transmission: 700r4 in both
If I wasnt getting married next month and moving away to go back to college (For high performance automotive:rockon: ) I would be all over it!!!
I would want to see it run before i took it home though....
Old Aug 23, 2003 | 08:20 PM
Guest
Guest
Posts: n/a
Try visiting the LS1 swap sticky at the top of the board. It answers all your questions and more.
Old Aug 23, 2003 | 08:47 PM
cd90rs's Avatar
Car: 1990 Camaro RS
Engine: 96 LT1
If that deal is legit thats an awesome price.
Old Aug 24, 2003 | 01:26 AM
Guest
Guest
Posts: n/a
I think thats why nobody has taken it, is that thing scorching hot or what???
500 miles, 6 speed, doesnt add up to 1900, more like 3900 or thereabouts.
hectre13
Dec 11, 2023 08:14 AM
Orr89RocZ
Apr 25, 2016 08:28 AM
86White_T/A305
Aug 17, 2015 12:16 AM
ChevyZ71
Aug 13, 2015 07:30 AM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
