Found a GREAT engine combo list
Old Sep 2, 2003 | 05:14 PM
mdricken's Avatar
Car: 92 Camaro
Engine: ZZ4 Crate Engine w/Hot Cam
Transmission: Rebuilt 700R4 with Transgo and MW 3
Axle/Gears: 3.73 Eaton Posi
I did a search for engine combos one time and came up with this - over 100 tested combos w/350s and 383s!!
Most combos are from reputable magazines like Chevy HP and Carcraft.
Here is the site:
http://www.ryanscarpage.50megs.com/combos1.html
Old Sep 3, 2003 | 01:58 PM
86BirdSE's Avatar
Car: 1986 Pontiac Firebird S/E
Engine: LG4 TPI Conversion
Axle/Gears: 3.42 SLP Posi 10 Bolt
Combo #1 is what I'm building, except it's not as big of a cam... and yes, if my calculations are correct, I will be doing right near 400 ft/lb of Torque...
and torque is king from light to light
Old Sep 5, 2003 | 10:42 AM
anymethod's Avatar
Car: 1986 Trans Am
Engine: carb 305 LG4
Transmission: TH700-R4
Thanks for the site mdricken. Of course now I am stuck between LT1 swap and 383 buildup. The 383 may be alot more expensive though.
~Matt
Old Sep 5, 2003 | 04:37 PM
82sportcoupe's Avatar
Wow, combo #1 is identical to mine except I have more lift due to the 1.6 ratio rockers.
Old Sep 24, 2003 | 01:48 PM
Trevor86TA's Avatar
Car: 86 Trans Am
Engine: 406
Transmission: TH350, 4200
Axle/Gears: Moser 9", 3.89
I saw that one last spring and couldn't find it again.
Thanks!
Old Sep 27, 2003 | 02:09 AM
Abaddon_fallen1's Avatar
Car: city bus
Engine: turbo diesel
Transmission: auto
Axle/Gears: be damned if I know, it's not mine
engine combos
I'd say combo 103. With that compression ratio (9.0:1) it's still good enough to cram between 4 to 6 psi of boost (low boost, just to be safe). Even more insane torque and horsepower.
:hail: :hail: :hail: :hail:
Old Sep 27, 2003 | 02:11 AM
Car: city bus
Transmission: auto
torque
It's alive, alive I tell you. they said it couldn't be done, but who's laughing now?! Mwuhahahahahahahaaaaaaaaaaaaaaaaaa..........
(insane lughter continues)
Old Sep 28, 2003 | 10:11 PM
87trans's Avatar
Ha!!, did you guys see this? At the top where you can click on the words, click on " car words that are in the bible". you should find it funny or... http://www.ryanscarpage.50megs.com/carwords.html
Frozer!!!
Jan 19, 2024 04:55 PM
NinjaNife
Aug 23, 2015 11:49 AM
bjpotter
Aug 12, 2015 06:06 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
antares57
Aug 6, 2015 07:47 AM
