FAST BURN 385 any one got it? would converting to tpi kill HP?
Old Sep 8, 2003 | 12:05 AM
Timbo89GTA's Avatar
Car: 89 Trans Am GTA
Engine: 383 TPI
Axle/Gears: 3:27
this is the parts i wanted, but with the 383. want tpi though wondered if it would kill the 430hp with hot cam?
she is a beaut
Attached Thumbnails FAST BURN 385 any one got it? would converting to tpi kill HP?-zz430c3.jpg
Old Sep 8, 2003 | 10:06 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
It will not produce anywhere near the HP with TPI as it will if built as it is advertised.
It will require the SDPC Vortec TPI base, since the Fast Burn heads have their intake ports in the Vortec (raised) location. You could drill holes in your existing intake and make it bolt up, maybe; but it might not even completely cover the ports in the heads, and certainly wouldn't flow near what the heads are capable of.
With that base, a good bit of the restriction in TPI is opened up. You could probably get it to within 50 HP or so of what you could get using a carb with an otherwise identical setup (same CID, cam & exhaust).
AFAIK that motor in the pic is long discontinued, although the parts to mostly clone it are all available.
Old Sep 9, 2003 | 10:07 PM
87WS6's Avatar
Car: 1992 Formula Firebird
Engine: 305CID (LB9)
Transmission: World Class T5
Axle/Gears: 10-bolt, 4.10 gears
Is that base really that good? Becuase I was thinking about the 350 HO for my car with that baseplate. Could that really bring the power up that much over the stock style TPI base?
Old Sep 10, 2003 | 10:26 AM
wm_sorg's Avatar
Car: 1991 Formula Firebird
Engine: 2001 LS1 Modded
Transmission: 2001 4L60E Yank SS3600 TC
Stealth RAM, Mini RAM, and Super RAM setups eliminate many of the bottlenecks of TPI. I am sure they can feed that beast while allowing you to exceed carb horsepower numbers.
Old Sep 10, 2003 | 03:16 PM
Mark305TBI's Avatar
Car: '00 Chevrolet Corvette
Originally posted by RB83L69
I
SDPC makes a cloned crate version, just without the ZZ430 valve covers. Look in their Custom Engines section. It's just a Fastburn 385 crate with the hot cam.
Old Sep 21, 2003 | 10:18 PM
badbird88's Avatar
I would not use a stock TPI unit but at least the ACCEL superram or miniram like sorg mentioned.
Another thing to think of...I hope you get a 12 bolt or 9" ford and a upgraded tranny or you will be breaking them very soon after you get the engine in. That is a lot of HP and torque and if you get the right set of tires on it that will hook up good...BOOM.
Old Sep 21, 2003 | 11:58 PM
bes217's Avatar
I think that with the SDPC base and the largest runners you can buy and major porting work on the upper that you could get the advertised HP with TPI. I will take some time though to do a good job porting the upper.
Old Sep 22, 2003 | 03:15 PM
unknown_host's Avatar
Car: 1989 Iroc Z L98
More horsepower under the curve, but I will bet money that peak is no different between that motor with a good carb and with a $2000 fuel injection setup.
Fast355
Dec 2, 2016 06:33 PM
gta power
Aug 13, 2015 06:15 AM
Sanjay
Aug 12, 2015 03:41 PM
89-S-dime
Aug 12, 2015 11:57 AM
