Car Geometry
Car: Z/28
Engine: 355
Transmission: Turbo 400
stability i would think that it depends on the rest of suspension setup (spring rates swaybars etc.) , but weight distribution yes and rearward weight transfer yes. I would set the car up on a skid pad and dial it in.
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
Originally posted by D M N
i was talking about the kind of setup the 4th gens have i mean they are recesed deep in the firewall
with 4thgens, they didnt set the engine back.. the firewall just mearly went forward.... the engine sits under the cowl because some designer at GM thought having a huge sloped windshield was a good idea
in a 4thgen, the engine is in the same place that it is on a 3rdgen.
Car: Right now 93 Lumina
Engine: 3.4 DOHC
Transmission: 4T60-E
Originally posted by demonchild
i always thought that the engine was so far back in the 4th gen cars to help eliminate backyard meachanics.
Transmission: 4L80E/4L80E
Re: Car Geometry
ok will moving the engine farther back into the firewall improve stability and more weight into the rear??
You can see what the factory did in the 4th gens. Certainly curtails casual shade tree activity.
Car: 91 Camaro Vert
Originally posted by AJ_92RS
150+ MPH w/275 HP is the reason of the sloped windsheild. :rockon:
3rdgen firebirds have a lower drag co..
Linson
Aug 21, 2015 02:12 PM
