84 chevy truck 350
Old Oct 9, 2003 | 01:13 PM
IROCaholic's Avatar
Car: 89 Camaro RS
Engine: 350 carbed now
Transmission: World Class T5
Axle/Gears: Peg Leg w/ 3.73's
84 chevy truck 350
Alright my friend just bought a RS with a 305 and we have been looking for a cheap 350 to throw in his car and we found one out of an 84 chevy truck. Its a good deal,but I was wondering what the hp and tq numbers would be on this engine . In the early 80's thats when gm was having the problems with emissions and we making real weak engines, my friends 80 camaro only had 190 hp for his 350. I was just wondering becuase I dont want my friend to waste his money on an engine that doesnt even put out 200 hp. I appreciate your help.
Old Oct 9, 2003 | 02:41 PM
Guest
Guest
Posts: n/a
It wont put out 200hp, I'd bet.
My advice? Swap the cam. Cheap, easy.
Old Oct 9, 2003 | 03:28 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
I'd say that motor might make a whole 140hp probably less with 250 lb/ft TQ.
It could make a good core motor, or cheap shortblock.
Old Oct 9, 2003 | 06:28 PM
IROCaholic's Avatar
Car: 89 Camaro RS
It has to make more than 140 hp , the Lg4 has that much power. I was thinking probably 170 or 180.Anyway what makes it that weak?is it the cam or the compression ratio.He is on a really tight budget so however he buys the engine is how its going to stay for a while.an Lo3 makes 170 hp and 255 tq, it would be a waste to swap a 350 that doesnt make much more power.
Old Oct 9, 2003 | 09:48 PM
Guest
Guest
Posts: n/a
I'm sure its some of both, but I'd bet you a dollar its got a peanut cam. Just get rid of that with a decent cam and it should be good to go.
Old Oct 9, 2003 | 11:57 PM
Cronic3rd's Avatar
Car: 98 Z28 vert
Transmission: automagic
Axle/Gears: 2.73 - boo racing yay MPG
As long as you 305 isn't of the TBI sort you could use the heads off of it.
Old Oct 10, 2003 | 07:36 AM
IROCaholic's Avatar
Car: 89 Camaro RS
So 305 tbi heads wont fit a 350 or is it just a older 350 that it wont fit, because he was planning on putting his 305 heads on there until he could get some vortecs.
Old Oct 10, 2003 | 01:08 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
TBI heads will fit, they just aren't good for much power.
Old Oct 10, 2003 | 01:23 PM
scottland's Avatar
Car: '82 Z28
Engine: 350HO
Transmission: M4
keep the short block, vortec heads($450) comp XE262 or so (~$190) edelbrock RPM Vortec ($179) and a good HEI distributer ($149) about $1000 bucks and you'll have 320+ hp 350+lb tq
or keep the motor the way it is w/ ~170-190hp , 270-290 lbs tq
Old Oct 10, 2003 | 01:58 PM
ME Leigh's Avatar
Car: 82 Z28
Transmission: TH350
LS9 350/V 8 175 275 K10,K20 73-86
LT9 350/V 8 160 260 K20,K30 81-86
But a tired old engine will have much less power, compression, efficiency.
jhawkeye
May 25, 2022 06:33 PM
Reborn756
Sep 4, 2015 03:42 AM
Eric-86sc
Aug 24, 2015 09:01 PM
NinjaNife
Aug 23, 2015 11:49 AM
theshackle
Aug 22, 2015 06:52 PM
