Able to hook Up TBI ?
Old Oct 10, 2003 | 10:36 PM
StormShadow's Avatar
Car: 91 Camaro Rs
Engine: 305 tbi
I'm looking for the future to replace my 305 with a 350.
I found this
http://www.chevypartx.com/rebuilt_en...-350RLB-4.html
First off would I be able to hook my tbi up to this? And Second Is it worth the money?
Scott
Old Oct 11, 2003 | 12:26 AM
IROCaholic's Avatar
Car: 89 Camaro RS
Engine: 350 carbed now
Transmission: World Class T5
Axle/Gears: Peg Leg w/ 3.73's
Well I am not sure if in will or not because for fuel delivery it says carb, but at the bottom where it says notes , it says tpi roller cam. You should be able to bolt the tbi manifold to any 87 and up small block with center bolt valve covers or if it has older style heads you can get a carb intake and buy a tbi adapter plate from turbocity.com and you should be set.I personally wouldnt pay that much for a rebuilt long block,but its gonna be hard to find one for cheaper. It all depends on what you want to do and your budget.Good luck.
S10K20
Oct 7, 2015 06:45 PM
Camaroguy2
Sep 22, 2015 08:22 AM
Denricci22
Sep 18, 2015 09:02 AM
Glowsock
Sep 11, 2015 11:09 PM
Wylecoyote08
Sep 8, 2015 08:26 AM
