distributor gear
Old Oct 26, 2003 | 12:12 PM
roaddawg's Avatar
Car: 86 sc
Engine: 305 lg4
Transmission: 350 turbo
distributor gear
I am going to swap a old style hei in a roller block does the gear
need to be changed or can i use the gear thats on it
Old Oct 26, 2003 | 12:49 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
No.
Just run it. The gear does not care what the design of the lifters is; it only cares what material the cam is made out of. 99.999% of all hydraulic street rollers, including 100% of stock ones, are made out of the same cast iron as typical flat-tappet cams.
Old Oct 26, 2003 | 09:01 PM
cdartz's Avatar
Roller blocks need a distributor with a hardened gear. I'm running an early 80s style distributor in a 92 roller block in my LT, and I had to get a hardened gear for it.
eightsixseven
Dec 16, 2024 01:50 PM
jklein337
Sep 19, 2018 06:23 PM
beastin91rs
Oct 9, 2015 07:38 AM
mddaniel
Sep 8, 2015 05:16 PM
86IROC112
Aug 17, 2015 07:57 PM
