car is completely dead
Old Nov 5, 2003 | 08:04 PM
tony1784's Avatar
Car: 85 Trans Am
Engine: SBC
Transmission: TH400
Axle/Gears: Moser/Strange 9"
I just dropped in my 383 and got everything hooked up. Now everything on the car is dead: lights, starter, windows, wipers....... The only thing that works is the alarm that keeps going off and giving me ****. I dunno where to even begin looking for problems. All the power and grounds look ok. Any help?
Old Nov 5, 2003 | 09:40 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Fuse box?
Old Nov 5, 2003 | 10:57 PM
tony1784's Avatar
Car: 85 Trans Am
Engine: SBC
Transmission: TH400
everthings fine in there
Old Nov 6, 2003 | 06:15 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Small wire(s) that go on the same starter terminal where the battery cable goes are not hooked up
Old Nov 6, 2003 | 12:35 PM
wm_sorg's Avatar
Car: 1991 Formula Firebird
Engine: 2001 LS1 Modded
Transmission: 2001 4L60E Yank SS3600 TC
Chances are you have a bad ground. There is a ground strap that goes from the chasis to the engine (usually where one of the trans bellhousing bolts are.) More than likely this is your problem.
Also make sure your batter cables and b+ wires are not interanly corroded and britle.
Old Nov 10, 2003 | 12:19 AM
tony1784's Avatar
Car: 85 Trans Am
Engine: SBC
Transmission: TH400
thanks alot you were right
Terrell351
Jun 13, 2021 01:13 PM
TheExaminer
Aug 26, 2015 04:59 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
hokis
Aug 9, 2015 03:57 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
