found a L98
Old Dec 2, 2003 | 04:31 PM
no1kicker's Avatar
Car: 1991 Trans Am
Engine: 5.3L
Transmission: auto
found a L98
Hey guys,
I threw a rod last month and just stumbled upon a guy with a 90 vette. It has 68k miles on it and he's going to do the LT1 swap, so he said I could have his engine for $500. I think it's a good deal, what do you guys think? It wouldn't include the accesories or harness. But I can use mine from my 91 LB9. What could I do about the oil pressure sender? And I can use my old ECM right? I mean an L98 is an L98, right? I know I need a new prom chip, will both a vette and f-body one work?
Old Dec 2, 2003 | 07:03 PM
bes217's Avatar
I would use a corvette chip if it is a corvette engine, but everything else should hook up just fine.
Old Dec 4, 2003 | 09:42 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
The engine itself is basically the same except it probably has aluminum heads (f-body has iron) and different computer programing.
EDIT: Almost forgot... i think the Corvette has a different water pump than the f-body. That may be only the older vettes, but its worth checking before you drop it in.
Old Dec 10, 2003 | 04:00 PM
kfoley's Avatar
Car: '85 Z28
Transmission: WC T5, 3.23 posi
That doesn't sound too bad with low mileage, but I would make sure you see it run before you buy it and make sure it doesn't smoke or anything.
F-body driver
Mar 6, 2023 11:44 AM
J-money
Jan 4, 2019 09:45 AM
tglennon11
Sep 23, 2015 05:30 PM
rudolphschenker
Sep 4, 2015 02:41 AM
Formula_88AE
Sep 3, 2015 01:47 PM
