L98 Died... LT1 ready to go in
Old Dec 23, 2003 | 04:21 PM
dj haf's Avatar
Car: 1990 IROC-Z
Engine: 350 L98
my L98 died on me... time for a new engine, so i called up a few junk yards and found myself a 94 LT1 with wiring and EVERYTHING for $500. im having a shop put the engine in because thats where my car's at right now... but what do i need to swap the LT1 into my 1990 IROC-Z. fuel pump is a few months old... pretty new. what parts should i take from the car im taking the LT1 from, and is there anything i should do to the LT1 before i put it in the iroc? thanks guys
Old Dec 25, 2003 | 06:44 PM
wm_sorg's Avatar
Car: 1991 Formula Firebird
Engine: 2001 LS1 Modded
Transmission: 2001 4L60E Yank SS3600 TC
If your stock fuel pump is new you should be ok. As far as the LT1 goes ou should replace the optispark and water pump. Also check the rear of the intake gasket for leaks.
Old Dec 26, 2003 | 01:03 AM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
this would be a great time for headers. i recomend the hedman hedders LT's or shorties. they are both great and the price is right.
Old Dec 26, 2003 | 01:15 AM
pasky's Avatar
Car: 1991 RS Camaro (Jet Black)
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
Im purchasing an LT1 and want to put headers on it while im installing it, got a link to those headers you just mentioned? Or will any headers for an LT1 fit on a thirdgen? Thanks.
Old Dec 26, 2003 | 01:38 AM
mw66nova's Avatar
Engine: 7.0L
an lt1 has the traditional O OO O exhaust port just like any other sbc. if the one you have has an O O O O exhuast port, then you have an ls1. i don't really know a whole lot about the header selection for a 3rd gen/ls1 swap except the ones at thirdgenresource.com
Old Dec 26, 2003 | 09:15 AM
pasky's Avatar
Im going LT1, not LS1 . I know the difference hehe. I just want to make sure they will clear ok if put into a thirdgen if its meant for a 95 z28. Thanks for the reply.
Old Dec 26, 2003 | 09:24 AM
mw66nova's Avatar
Engine: 7.0L
yeah, LT1's have the same outside dimensions as a traditional sbc.
Old Dec 26, 2003 | 10:54 AM
pasky's Avatar
So any headers for an LT1 4th gen will work in a 3rd gen using an LT1?
Old Dec 26, 2003 | 10:56 AM
posbird87's Avatar
Car: 87 formie
Engine: none
Transmission: none
yes
~edit~ to be more clear you can use hedders that fit a traditional sbc, like your old tpi on the lt1 engine because of the O OO O exhaust port patterns so you wont have to buy a set for a 4th gen. you can just get a set for a thirdgen.
Old Dec 26, 2003 | 11:35 AM
pasky's Avatar
Ok cool beans, I knew they bolted up, but thought that maybe the thirdgen crossmember or something else obstructs it, thanks.
Old Dec 26, 2003 | 08:41 PM
mw66nova's Avatar
Engine: 7.0L
any thirdgen specific header will bolt up to your LT1, there are no differences in the outside of the motor then the traditional sbc that is already in your car.
Old Dec 26, 2003 | 11:39 PM
Trans Am#5's Avatar
Car: 1987 Trans Am
Engine: Lt1
Only headers meant for 3rd gen TPI car will bolt up to and have no/minimal clearance issues when used with an LT1. You cannot use a 4th gen specific LT1 header in a 3rd gen. The down tubes will not clear.
Old Dec 27, 2003 | 04:48 AM
pasky's Avatar
Alrighty, thanks for the info guys .
Old Dec 27, 2003 | 11:21 AM
demonchild's Avatar
i thought that certain headers would help a LT1 engine more than others because of the "D" exhaust ports.
Old Dec 28, 2003 | 09:00 AM
Dave Y's Avatar
Car: 04 Xtreme Blazer
Engine: 4.3L V6
if you have a 700R4 you will need a 92/93 LT1 throttle body and throttle cable bracket
91chevyz28
Feb 10, 2022 07:58 PM
FormulasOnly
Jul 23, 2018 08:47 AM
david068513
LSX and LTX Parts
Nov 15, 2015 11:37 PM
david068513
Sep 13, 2015 11:24 AM
david068513
South East Region
