optispark confusion
Old Dec 27, 2003 | 09:17 PM
lt1g3n's Avatar
Car: 1983 Camaro
Engine: Lt1 (383 project)
optispark confusion
I need to get my optispark unit for my lt1 now, but i dont know the exact year of the motor, but the cam pin is the short one, the # on the timing cover is # 12550032.. Im not sure if i need the 92-94 , or the 95-97. I was looking on a site with the pictures, but just not positive. appreciate the help, thanks.
dave
Old Dec 27, 2003 | 10:07 PM
pasky's Avatar
Car: 1991 RS Camaro (Jet Black)
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
Ummm im not totally sure, but are they visibily different? I know the 94+ optispark's are vented. Perhaps you can distinguish them by looks? *shrug*
Old Dec 27, 2003 | 10:11 PM
Trans Am#5's Avatar
Car: 1987 Trans Am
Engine: Lt1
There are two different designs of Optispark also known as distributors availible. One is the first design without the vent P/N 10457702. This design fits 92-94 Corvette and 93-94 Camaro and Firebird. The other is the second design for later model vehicles P/N 1104032 and has provisions for a vacuum line that runs from the intake manifold to the Optispark. This model fits 94-96 fullsize passenger cars and 95 and later Corvette, Camaro and Firebird.
Look and see of it has a vent on your original optispark at about the 4-5 o'clock position I believe.
Old Dec 27, 2003 | 10:20 PM
lt1g3n's Avatar
Car: 1983 Camaro
i would , but i dont have an original, i use to have a 305 =P, now the lt1 is in there needing some spark
Old Dec 28, 2003 | 08:10 AM
lt1g3n's Avatar
Car: 1983 Camaro
op
not sure if you saw my last post , it failed to post but i still see it =p... but i dont even have an original one because i put this lt1 in my 83 and i never had an opti for it , now im needing one
Old Dec 28, 2003 | 08:52 AM
Dave Y's Avatar
Car: 04 Xtreme Blazer
Engine: 4.3L V6
the non-vented timing cover just has a small hole for a little stub shaft that splines into the center of the cam sprocket that drives the opti, the vented ones have a large hole where the rear of the opti sits against the timing sprocket and is driven by the cam dowel , if you have the large hole, and the cam dowel is flush with the cam gear, then you have the wrong cam or cover
Galaxie500XL
Feb 1, 2020 04:53 AM
Jorlain
Oct 8, 2015 01:57 AM
bubbaz28
Sep 18, 2015 02:09 PM
Denricci22
Sep 18, 2015 09:02 AM
L0tuS
Sep 4, 2015 11:16 PM
