Best way to haul and engine?
Old Jan 6, 2004 | 06:55 PM
ZROC86's Avatar
Car: 1999 Trans Am WS6
Transmission: A4
I may be getting a TPI 350 soon and the only way I can go get it is witha pick up truck. What would be the best way to strap down the engine?
If this is the wrong forum please move.
Old Jan 6, 2004 | 07:03 PM
pasky's Avatar
Car: 1991 RS Camaro (Jet Black)
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
Find someone with a cherry picker, get a wooden pallete, one that can hold the weight, strape it down, put it in the truck and go.
Old Jan 6, 2004 | 07:17 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
I ws able to put both the engines I got on a hitch haul on the back of my Blazer
Didn't get too good milage though
Old Jan 6, 2004 | 11:42 PM
TKOPerformance's Avatar
Car: '86 Camaro, '02 WRX, '87 K5, '67
Engine: 350 TPI, 2.0turbo, 383 in the works, 289-4BBL, 232, A-head 4-cylinder
Transmission: T56, 5-speed, 700R4, C4, T176, semi-auto 2-speed
Axle/Gears: 3.73, 3.90, 4.88, 3.55, 3.54, 7.00
Get an old tire and plop the engine dron in the center of it, so the deep part of the sump is in the hole. Then tie it down with rope or rachet straps. I've hauled at least five engines like this and never ahd one damaged.
Old Jan 7, 2004 | 12:04 AM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
i am all for the tire tip.....hauled engines all around using that idea ......strap em down tight and you're golden....works like a charm.
Old Jan 7, 2004 | 04:02 AM
pskel350's Avatar
the tire is a very good way to haul an engine, used it a few times myself. however i got sick of finding an old tire everytime i had to transport an engine, so i just built an engine cradle. like the ones you find in summit racing. works better, and looks better hauling the engine too
Old Jan 7, 2004 | 04:59 AM
ede's Avatar
ede
sit it on an old tire, it won't go any where. if you want a little extra security strap it down with a couple ratchet straps.
Old Jan 7, 2004 | 11:35 AM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
Famous last words. We had a parts driver haul one in a van like that. He had to hit the brakes hard to avoid an accident. The engine came forward & took out the passenger seat, good thing no one was in it. Words of wisdom, strap it down.
Old Jan 7, 2004 | 11:40 AM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Another way is to set the engine on the oil pan and place jack stands under each motor mount. Be sure to tie the engine down so it doesn't move.
Old Jan 7, 2004 | 03:53 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Build a 2x12 "box" that goes around the pan, the engine sits in/on the "box" with the weight on the pan rails.
A lot of crate engines are shipped that way. You'll still have to tie it down to keep it from sliding forward/backward or side-to-side.
Old Jan 8, 2004 | 12:23 AM
86z/92rs's Avatar
Car: 86Z/92 RS Camaro
Engine: 357 vortec finished. need tuning
Transmission: Still works
Axle/Gears: need 3.73
Another vote on the tire method. Just go to your local tire dealer. That’s how I got my truck tire for free which I used to haul a LT-1 motor with tranny to Las Vegas. Definitely strap the engine down. When choosing a tire the wider the better.
84z96L31vortec
Aug 20, 2017 12:16 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Reddeath210
Oct 6, 2015 08:20 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
