Cheap-a$$ LT1 swap continued
Old Jan 12, 2004 | 10:15 PM
SERPENT99's Avatar
Car: 89 IROC
Engine: 95 350 LT1
Working on the VSS. I replaced the stock VSS with the speedo drive gears, I had to drill a shallow hole in the output shaft for the speedo gear clip, had to use a dremel drill with a carbide bit. I bored out the reluctor and put it up where the governer gear used to be. Now I have to either make the stock sensor work somehow or buy the 4x4 sensor for $75. $75 is still better than paying $300 for a tailshfit kit.
I used a buick roadmanster LT1, any ideas on the AC hoses?
Old Jan 12, 2004 | 10:28 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
Re: Cheap-a$$ LT1 swap continued
Hoses are going to have to be custom.
Old Jan 12, 2004 | 10:36 PM
TexasLT1's Avatar
Car: '92 RS
Where is the a/c compressor for the roadmaster at? I haven't seen the acc. setup on those.
Old Jan 13, 2004 | 05:55 AM
ghostrider's Avatar
Car: 1987 Firebird Formula
Engine: a less than exciting LG4
I believe it is at or near the same location as on the F-body LT1s. I remember seeing somewhere that the same issues concerning the A/C compressor existed but of course now that I try to find it I can't.
Old Jan 13, 2004 | 07:44 AM
TexasLT1's Avatar
Car: '92 RS
well thats what I was wondering. If its in the same location, the a/c lines would be the same as the LT1 setup. In that case, I'm still in search of the part number for the compressor fitting I've got. All I know is its a CarQuest part that bolts to the back of the compressor with two 90* tubes coming that are able to swivel 360* to allow you to turn them any direction you need. I've got that with a rubber hoses connecting to the evaporator and a steel braided line connecting to the condensor.
Old Jan 13, 2004 | 09:29 AM
SERPENT99's Avatar
Car: 89 IROC
Engine: 95 350 LT1
The carquest website isn't much help. I also noticed it seems the fittings on the R-12 based systems seem to have a different thread pitch than the fittings on the R-134a system. They look like they'll cooperate with a little lube and some big wrenches.
Yes, the compressor is down where you have to notch the frame.
How about a picture of the fitting TexasLT1?
I trimmed the stock VSS sender down so it fits inside the back of the trans, I have to figure out a way to wire it and mount it now. I may just buy the $75 sender if I can't think of a reliable solution.
Old Jan 13, 2004 | 10:40 PM
TexasLT1's Avatar
Car: '92 RS
Yeah the CarQuest website is absolutely useless. Your best bet is to go to one of the parts stores and look through the catalog.
Unfortunately I do not have a photo of it anywhere. In my infinite wisdom I didn't take any useful photos when we did the swap.
As far as the different thread pitch, it wont matter. The fitting comes with a bolt, but you can put in any one that will fit. I've got a standard bolt in there, I believe its 5/8, but thats going from memory from 2 years ago.
Old Jan 14, 2004 | 07:28 PM
tamatt27's Avatar
Car: Kitt
Engine: Classified
Axle/Gears: Moser/4:11
I've got a '96 9C1 LT1 that I'll be putting Roadmonster accessories on. I'll prob be following your swap pretty closely.
midge54
Sep 2, 2020 07:13 PM
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
sreZ28
Aug 14, 2015 07:48 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
