88 305 TPI swap to 91 350 TPI
Old Jan 28, 2004 | 02:36 PM
gchu's Avatar
Car: 88 Iroc Convertible
If I swap a 91 350 TPI in place of my 88 305 TPI - can I just reuse my stock wiring harness and MAF sensor? I know I would change the computer as well, but would everything else hook up?
Old Feb 4, 2004 | 12:30 PM
SydwayzTA 86's Avatar
Car: 1986 Trans Am
Engine: 5.7L TPI
the wiring harness and maf will be fine, thing you will need to replace is a 350 Knock Sensor, get some 22lb injectors the 305 uses 19lb, I personally went to 24lb and a new prom for the 350
I also notice you said a 91 TPI, that you would be doing some wiring changes because 90-92 was speed density, not mass air flow
Old Feb 4, 2004 | 08:44 PM
88Z's Avatar
88Z
Car: 88 Iroc
If you're gettin the complete motor off that 91, I'm pretty sure that you can use that same harness and maf sensor. Just get a new chip burned or even a computer out of an 88 350. I wonder how it would run if you just hooked it up to the 305's computer? I'm doing almost the same exact swap so i'd like to know.
Old Feb 7, 2004 | 06:47 PM
88Z's Avatar
88Z
Car: 88 Iroc
O yeah! Don't forget about the cold start injector. You'll probably want a computer out of an 89 L98. That's when they had you're same harness and the 89's also didn't have that cold start injector, just like you're 91 motor.
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
wruiz
Aug 13, 2015 09:07 PM
st.evel07
Aug 13, 2015 06:15 PM
gta power
Aug 13, 2015 06:15 AM
Sanjay
Aug 12, 2015 03:41 PM
