Estimated cost of machining for splayed caps?
Old Feb 2, 2004 | 04:14 PM
2laneblacktop's Avatar
I'm going to call the machine shop this weekend, but I was wondering how much it has costed those of you who have them, to have the block machined for splayed caps. NOT including the price of the caps themselves. Just the machining part, including align honing.
Old Feb 2, 2004 | 04:19 PM
Sorry, this should be in Tech. Moderators, move if you would like.
Old Feb 2, 2004 | 06:50 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
After you call, let us know how much it's going to cost you.
Old Feb 2, 2004 | 07:41 PM
Pony Killer's Avatar
Car: 1986 Z28
Engine: 355
Transmission: th400
should be round 200 bucks give or take.
Old Feb 3, 2004 | 05:22 AM
ede's Avatar
ede
yep around 200, here it's 225 plus the cost of the caps, so you're looking at close to 500 dolalrs.
Old Feb 3, 2004 | 06:27 AM
85TransAm406's Avatar
Car: 1985 Trans Am
Ask them if they can align bore the block, then just finish it up with an align hone. This will remove most of the material from the caps, instead of the block, and reduce the chance of there being slack in the timing chain.
An align hone uses the end crank journals to establish a centerline, as a align bore uses pilot bearings, allowing corrections to be made in crankshaft centerline placement.
They may want to do it this way anyway, as a hone would take longer to remove the material from the caps. I would just ask, to be sure.
gta892000
Aug 11, 2019 11:16 AM
db057
Apr 28, 2019 07:45 AM
NastyEngines
Group Purchases
Sep 8, 2015 10:14 AM
TBRays98
Sep 6, 2015 05:05 PM
89-S-dime
Southern California Area
Sep 4, 2015 10:34 AM
