Crate 350HO vs L98 Modified
Car: 2003 HD 1500 4 door Chevy
Engine: 6.0
Transmission: 460LE
I was about to buy a new 350 HO. Car Craft took one slapped headers, Air Gap manifold and a 750 and dynoed at the flywheel thru mufflers 368 HP and 401 lbs of Torque. Sounds good to me.
My local hot rod bud suggested I take my stock L98 longblock and buy a good set of AFR heads ($1500-1600 / 2.02 / 1.60 64cc) and a great cam ($200) along with some misc stuff (lifters......) will make more power overall.
In comparing cost of buying new Crate (2200 , selling L98 for 500) or buying heads plus cam ($2000) plus install.
Any input is appreciated as I am ready to make a move.
I lean towards the mods but a brand new motor is hard to beat for 2200.
Car: '87 Formula
Im assuming you dont have TPI from your sig.
For 200 bucks more (if you can get 500 for your l98 block, great) I'd just as soon have a new engine with a warranty and guaranteed new (and almost guaranteed the advertised HP), and not have to mess with changine heads or anything.
Just my opinion.
Just my opinion.
Car: 89 Camaro RS
Engine: 350 carbed now
Transmission: World Class T5
Axle/Gears: Peg Leg w/ 3.73's
I agree with 87Formula4bbl I would definetly go with the new engine. I would actually prefer to do the work myself becuase I want the satisfaction of know I did everything I could on my car. But it will take a little more time to do everything and "time is money". So I would go with the crate motor. Also PM me when you want to sell that motor I have a buddy who would more than likely buy it for $500. And I we can come pick it up. Good Luck man.
Engine: 6.0
Transmission: 460LE
Thanks for the input IROCoholic. When I pull the L98 I will give you a call. I live in Sugarland however the motor will be located in Houston when pulled.
I have not heard any argument for moding the L98. I will keep listening to see if anyone with a modified L98 chimes in.
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Engine: 6.0
Transmission: 460LE
Ive got 40k on the motor. It runs perfect however it is a former TPI car so the cam is limited. I would need a new cam and as I stated earlier I was looking at the right AFR heads.
Car: '90 RS
Engine: 377 LSX
RedLeader289
May 28, 2019 01:47 PM
