350 engine bored .40
Old Feb 17, 2004 | 10:59 PM
86z/92rs's Avatar
Car: 86Z/92 RS Camaro
Engine: 357 vortec finished. need tuning
Transmission: Still works
Axle/Gears: need 3.73
I understand that the engine would be a 357, but are there any draw backs to having it bored .40 over?
Old Feb 17, 2004 | 11:20 PM
Wootah's Avatar
Car: 88 Iroc-Z
Engine: 355ci
Transmission: WC-T5
thinner cylinder wall?
Old Feb 18, 2004 | 04:59 AM
ede's Avatar
ede
you'd need a new set of pistons but that's sort of a given.
Old Feb 18, 2004 | 07:18 AM
86z/92rs's Avatar
Thanks for the response.
Old Feb 18, 2004 | 09:10 AM
wesilva's Avatar
Car: 1966 El Camino Custom
Transmission: 200R4
Axle/Gears: 3:73 12 bolt with Brute Strength
350's generally have enough bore thickness to accomodate a .060" overbore. Sonic checking is recommended at that overbore for racing to insure the bore has not been compromised through bore shift, etc.. But at .040", there should be no concern at all.
I did hope you meant ".040" and not ".40" which is impossible with what you have to work with.
Old Feb 18, 2004 | 08:59 PM
86z/92rs's Avatar
Yes, I meant to type .040. Whats the possibility of getting the short block balanced without taking the internals out?
Old Feb 19, 2004 | 08:00 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Exactly zero.
Pretty hard to weigh stuff when you can't put it on a scale.
.040" over is kind of an odd size; the piston selection isn't as great as .030" or .060". But, for most typical street type uses, you shouldn't have any trouble finding what you want. Other than that, there's no particular disadvantage.
Old Feb 19, 2004 | 11:03 AM
unknown_host's Avatar
Car: 1989 Iroc Z L98
Originally posted by RB83L69
Exactly zero.
Agreed but there are so many parts for 350 derivatives nowadays that he shouldnt have too many problems finding a piston he likes.
Old Feb 20, 2004 | 03:19 PM
firefrombelow's Avatar
Re: 350 engine bored .40
Well, .30 over yields 5 Cubic inches, so I guess thats about right...There arent any draw backs that I can think of, besides thinner cylinder wall as said above...This really isnt a problem until you rebuild the motor again...People usually bore on a rebuild, to sort of "clean up."
Hope this helps...
Old Feb 20, 2004 | 07:28 PM
86z/92rs's Avatar
To All, thanks for all the help. I am going with a 357 with vortec heads.
Old Feb 22, 2004 | 02:21 AM
tpiroc's Avatar
Car: GM & Jaguar
Engine: Various
Transmission: Various
Axle/Gears: Various
Cool, sounds like a good project. Your piston options will be decreased with an odd bore size. It's been NO treat finding pistons for a 0.040" over 400
Old Feb 22, 2004 | 06:51 PM
cdartz's Avatar
Why .040 over? This won't really yield you any better power increases than .030 over. The more material you bore away now, the less you have left to play with in the future. What if you get a score in one of the bores? You want to have as much left to work with as possible down the road.
Old Feb 22, 2004 | 10:41 PM
86z/92rs's Avatar
The block needed to bored .04 since the ring on #2 cyl. went bad. Also the block was free. I will be taking some pictures of the up and coming project. Should have the motor ready for installation in 2-3 weeks. Just need to find a cherry picker to use during the installation. I have everything else.
Old Feb 23, 2004 | 12:02 AM
cdartz's Avatar
Well that explains it then. If you have to go .040 then there is nothing wrong with that.
Old Feb 27, 2004 | 06:23 PM
Kontrax's Avatar
Car: 86 Camaro
Engine: L98 350 bore .060 out, Carb power
Transmission: slusher 700 beatbox
i went with the .060 machine dude said it would be fine with all the forged molly stuff i put in it. a guy at the bodyshop down the road from me has an lt1 bored .090.... if his talk is anything like his body work then i know hes full of Shhh
Old Feb 29, 2004 | 11:26 AM
Meatikis's Avatar
Car: '86 Z-28
Engine: 350 bored .030 over
he must be... from what i know, thats not possible.
Old Feb 29, 2004 | 04:39 PM
Kontrax's Avatar
Car: 86 Camaro
same thing i was thinking man. like i said if his mouth is anything like his bodywork, then hes full of ****
Jake_92RS
Jan 28, 2020 10:37 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
NinjaNife
Aug 23, 2015 11:49 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
