Electrical problem need help!
Old Feb 22, 2004 | 07:06 PM
91tirespin's Avatar
Car: 91 camaro rs
Engine: 355
I'm trying to finish up my motor swap in my 91 rs. I've got everything hooked up and now I'm not getting any electrical power. The battery's pushing the right power, but its not getting to anything. Lights won't come on when i open the door, and nothing happens when I put the key in the ignition or turn it. Is there something somewhere not connected correctly, a fuse blown? What should I look for? And the motor swap is from a 305 tbi to a 355 carbureted.
thanks for any help...Jake
Old Feb 22, 2004 | 07:16 PM
Stryder's Avatar
Car: Camaro
Engine: 2.8L MPFI
Axle/Gears: Stock round ones
link by battery
I would look for a Fusible link that is blown!!!!!!!!!!!!
Fusible Links look just like a wire!!!!!!!!!!
Usually the link is more flexible than a normal wire and may have heatshrink covering the ends of the link connectorz!!!
Fusible Links simulate an inline fuse and can be sortof messy because they melt!!!!!
Have Fun
Old Feb 22, 2004 | 09:58 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
The fusible links you're looking for are on the wires at the starter solenoid.
Old Feb 22, 2004 | 11:14 PM
walterrao's Avatar
Car: 91 RS
Engine: vortec 355 hsr
Transmission: wct5
Axle/Gears: bg3.27
try cleaning your battery posts and cables. most of all battery problems are from there.
Old Feb 23, 2004 | 08:56 PM
91tirespin's Avatar
Car: 91 camaro rs
Engine: 355
I checked the fusible links and they are fine. The problem is that I"m not getting power to my fuse panel. What gives the fuse panel power? Does the distributor or ignition have anything to do with getting power to it? I've checked all my grounds and connections.
Old Feb 23, 2004 | 09:01 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
The fusible link at the starter solenoid.
toones
Jan 6, 2016 06:00 PM
BlackphantomZ28
Aug 22, 2015 01:00 PM
Dialed_In
Aug 20, 2015 01:45 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
