whaddaya know, the dam thing worked
Old Feb 22, 2004 | 07:40 PM
SERPENT99's Avatar
Car: 89 IROC
Engine: 95 350 LT1
I've been working on an LT1 conversion. I fired it up today, and everything worked! My home made wiring harness went right into closed loop after it warmed up. My home made VSS seems to work too. I was sure there would have been leaks or a few electrical fires. All the gauges worked too!
I did get an error code, MALF 26 CCP Electrical Fault. Can't be anything important, it don't light the CEL. Maybe it's because I have the air conditioning compressor relay unplugged.
I guess when I get the seats in I should take it for a ride.
Old Feb 22, 2004 | 08:30 PM
TexasLT1's Avatar
Car: '92 RS
Awesome! glad to hear it runs
Old Feb 23, 2004 | 03:57 PM
Stokdd's Avatar
Car: Yellow '92 Formula
Transmission: A4
Glad to hear it! Have fun in your new LT1
I'm hoping for the same....... I'm swapping my 350 TPI into a much lighter '72 Nova. My Firebird weighs above 3,400lbs as is, but the Nova weighs less than 1,500lbs (completely stripped, no engine/trans/driveshaft).
Old Feb 23, 2004 | 04:43 PM
wm_sorg's Avatar
Car: 1991 Formula Firebird
Engine: 2001 LS1 Modded
Transmission: 2001 4L60E Yank SS3600 TC
Please post details of the homade VSS. Congratulations!
Old Feb 25, 2004 | 01:40 PM
SERPENT99's Avatar
Car: 89 IROC
Engine: 95 350 LT1
I'm not home. I have pics of my VSS on my home server. I needed a speedo hookup and an LT1 type VSS. Conversion tail housings were expensive, so I put the speedo drive where the VSS was, then I bored out the reluctor for theVSS, moved it up the trans shaft where the governer used to be on the 4L60, then I modified the pickup so it fit inside the tail near the reluctor. I'll try to remember to send pictures, texasLT1 has the pics if he's around he'll probably post them if he sees this message.
Old Feb 25, 2004 | 02:13 PM
TexasLT1's Avatar
Car: '92 RS
Yup, let me get them hosted and I'll put them up.
Here they are.
Old Feb 25, 2004 | 02:19 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
you can also post them on this board... so they'll be up for as long as the board is.
just put in the location to them in the attach file box that is under the text box you type your msg into when you goto post
Old Feb 27, 2004 | 12:18 PM
irocmiller's Avatar
modification
Will I have to do all this with a 700r4, what will I have to do?
Ghettobird52
Jul 5, 2024 11:18 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
justin57
Aug 20, 2015 07:05 PM
Bob88GTA
Aug 18, 2015 03:31 PM
milk
Aug 10, 2015 06:26 PM
