TPI on Older Motor?
Car: 82' Z28 IROC Clone (SOLD)
Engine: 355
Transmission: Built TH-350
Axle/Gears: 3.73 Moser 12 bolt
TPI on Older Motor?
Ok, my car has some frame/suspension and body alignment issues because the car was wrecked, I fixed all I could and spent alot of money on the body interior and motor over the last 2 years. But some problems will never be fixed and I have a 6 hour drive to college next year. I found an 86 IROC 350 TPI 700R4 that has the main bearings gone in the motor, What all is involved with swapping an older motor bottom end, and putting the TPI unit and heads off the IROC on it? My motor is stout in my 82, But overdrive and fuel injection would be nice for next year, Plus some seals are starting to go in my heads so I figured these L98 heads would work nicely. My motor in question is a 78' 4 bolt main block. Was 86 a Roller motor? Or would it be a pretty basic swap? Could I use everything off the TPI car? Any other advice? I am not sure if I am gonna go through with this yet or not, My car looks great inside and out, But these little problems cause me alot of vibration and etc. If I get this other one I might swap out interiors and stereo and maybe even exhaust....
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Re: TPI on Older Motor?
EDIT: I forgot about the lifter differences. I do not think you can use roller lifters without modifying those heads. I may be wrong and someone with more experience will chime in.
Transmission: 4L80E/4L80E
350's didn't show up in 3rd gens until 1987 model year.
If the car has a 350 in it now, it isn't what came out of the factory.
1992rs/ss
Jan 31, 2025 05:10 PM
Sanjay
Aug 12, 2015 03:41 PM
