Putting LT1 in without AC.. AC later.. need pics of K-member mod..
Old Mar 5, 2004 | 12:17 PM
Thirim's Avatar
Car: 89 GTA
Engine: 350 LT1
I am forced to use LT1 Acc in my swap (lack of knowledge to fab something up for 3rd gen acc) .. It's $500cdn for a new AC Comp.. so I will opt for the $175 used.. Problem here is it has a 30day warranty.. and I will not have AC working in 30days .. SO I will get the engine going without it for now.. and then get it going later.. SO... I need to mod my K-member blindly.. Anyone have pictures or advice on this? I have heat.. and a hammer.. where do I pound?
Old Mar 5, 2004 | 12:23 PM
pasky's Avatar
Car: 1991 RS Camaro (Jet Black)
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
https://www.thirdgen.org/techbb2/sho...hreadid=226657
I actually had to pound back further on the top of the xmember throughout that indent I was off by 2 mm at the top. Thats about how much you need, you will also need to modify the clamshell so it will clear the AC.
Old Mar 5, 2004 | 12:43 PM
Thirim's Avatar
Car: 89 GTA
Engine: 350 LT1
give me a pretty good idea what and where to pound.. now abou this mod to the clamshell.. anyone have clear pics of that?
thanks.
Old Mar 5, 2004 | 12:50 PM
pasky's Avatar
Ummm I just did give you a clear picture. Just pound everything above that was pounded in that picture, make that a smooth hole starting from the top. As far as the clamshell, its a bit hard to explain, go to TexasLT1's swap guide and check out the pictures there, I didnt bother grinding because I was at it for 2 hours and wasnt getting anywhere I took my clamshell to a welder and told them to cut out the hump and weld in a piece of straight metal.
Old Mar 5, 2004 | 02:58 PM
Thirim's Avatar
Car: 89 GTA
Engine: 350 LT1
it was the clamshell i needed a picture.. texaslt1's pic is a bit hard to make out exactly what to cut.. Your pics were great... all that i needed. as far as cutting.. not a prob.. i have a torch, welder, grinder, chop saw.. sawzall.. something will do the job
again...
thanks.
Old Mar 5, 2004 | 06:18 PM
wm_sorg's Avatar
Car: 1991 Formula Firebird
Engine: 2001 LS1 Modded
Transmission: 2001 4L60E Yank SS3600 TC
I would convert to corvette accessories when you are ready for A/C. This will avoid the whole mess.
Old Mar 5, 2004 | 06:47 PM
pasky's Avatar
Problem is corvette accessories run 450 bucks or so. Its not even bad to just heat up the xmember and pound it back, hell it took me 10 minutes. I got the clamshell done at a machien shope for 20 smackaroos, Free + 20 > $450. Now I would agree if you had a corvette engine to begin with though.
Old Mar 5, 2004 | 08:56 PM
Thirim's Avatar
Car: 89 GTA
Engine: 350 LT1
can pretty much rule out the vette stuff.. You can count the # you see around in a summer on both hands.. and if one got wrote off... its sold b4 it gets out of the ditch..
then if you do find one... $$$$$$$$ for parts. I can't even get seats out of a 4th gen..
Old Mar 5, 2004 | 10:03 PM
TexasLT1's Avatar
Car: '92 RS
There really are no plans or measurements we can give you. The best way, if you could do it, would be to drop the engine in until the compressor contacts the frame so you could see exactly where to clearance it. If you can't do that, you can get close enough by heating up the crossmember in the are above the motor mount where it angles down for the engine cradle, basically from the top edge of the motor mount, straight towards the frame rail about 6 inches. You only need about 1/4" to 1/2" clearance, it doesn't take much, even less if you are using new motor mounts.
Old Mar 7, 2004 | 12:03 PM
SERPENT99's Avatar
Car: 89 IROC
Engine: 95 350 LT1
I cut the part of the AC bracket off that goes to the engine mount hole in the block. when I bolted the clamshell on the block, what was left of the AC bracket was close enough to weld to the clamshell. I had to use capscrews and file some notches to be able to get to the bolts on the back of the compressor.
The best part was after I mated the clamshell to the AC compressor, I took the clamshel and compressor and put them on the motor mount and it was real easy to see where the frame had to be beat back.
1984HO
Mar 19, 2021 11:59 AM
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
sreZ28
Aug 14, 2015 07:48 PM
NBrehm
Aug 5, 2015 07:57 PM
