v6-v8
Old Mar 15, 2004 | 10:15 PM
kevo2k6's Avatar
Car: 1990 Camaro RS
Engine: 3.1L v6
Transmission: 700r4 auto
v6-v8
im thinkin bout doin the swap from the v6 to the v8. what exactly am i gunna need to do this, and about how much is a v8 from the yard gunna run me?
Old Mar 15, 2004 | 10:17 PM
mmcdjs's Avatar
Car: 1991 Pontiac Firebird
Engine: 3.1 V6
Hey where are you located? I'm about to start the same thing with my 92 bird.
Old Mar 15, 2004 | 10:32 PM
kevo2k6's Avatar
Car: 1990 Camaro RS
Engine: 3.1L v6
modesto california, central valley
Old Mar 15, 2004 | 10:59 PM
pskel350's Avatar
basically the radiator to the tranny. best thing todo is a search on the subject, then ask any specific questions you have
Old Mar 16, 2004 | 12:01 AM
kevo2k6's Avatar
Car: 1990 Camaro RS
Engine: 3.1L v6
heres the list ive come up with
upper/lower motor mounts from v8
v8 radiator
and possibly a tranny unless i find a motor with one
my question is wut to do bout all the wiring any diagrams i can find sumwhere or will this be esier than i think?
Old Mar 16, 2004 | 12:23 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Being in California, I'll assume you have emissions testing at least, and probably inspection. That being the case, listen carefully.
You need a factory V8 donor car that's your year model or newer. Take everything out of it that's different with regard to the engine, and put it in your car. That includes that little iddy biddy list you started, and a whole bunch more. Add the tranny and wiring harness, by the way (the harness can be removed from the engine/chassis in one piece and re-installed - including the sensors that are attached to it).
Change the front springs. If your car is earlier than '89 or '90 or so, the radiator. And the tach.
Hoses, throttle cables, belts, AC ...
86camaro454
Nov 19, 2013 06:26 AM
kelham
Feb 24, 2008 11:16 PM
tourville
Interior Parts Wanted
Nov 6, 2006 09:48 PM
tourville
Oct 27, 2006 05:40 PM
