305 tpi to 350 tpi
Car: 89 iroc, 88 supra targa top
Engine: 350 tpi
Transmission: 700r
305 tpi to 350 tpi
hello, i'm new to this, so pardon me if i sound stupd. i swapped me 305 tpi to 350 of which i removed from a 1500 p/u. can i still retain all the 305 sensors, computer and injectors to make this 350 run properly. thanx
Transmission: 4L80E/4L80E
Welcome aboard.
Depends upon the 350, but being it's from a truck, most likely.
Adjustable fuel pressure regulator would be helpful in re-tuning. 22 lb injectors are typical for 350's, but with the AFPR, you can probably get by with the 19's of the 305.
Sanjay
Aug 12, 2015 03:41 PM
