New Project, v6-v8 Engine Combos
Old Feb 19, 2008 | 04:02 PM
kelham's Avatar
Car: 87 TA / 87 Firebird
Engine: 385 FastBurn / Performance 3.4L
Transmission: TKO600 / 700R4
Axle/Gears: Ford 9" / GM 10bolt
Im on my second build,
Rules-
I want to stay fuel injected
V6-V8 Swap
Supercharger
Im looking into the RamJet 350 as my swap, coupled with a Coan 700R4 Street Trans and a Ford 9" Rear w/ 389's
Ram Jet - http://www.crateenginedepot.com/stor...20-P22C53.aspx
They also sell the Ramjet intake by its self for around $1,500.
Would I be better off buying a blueprint engine w/ scat crank etc and strapping it onto that.
Blueprint - http://store.summitracing.com/partde...1&autoview=sku
Also what motor would hold up to 12psi of boost off of a D1SC Procharger better. My instinct would be going with the Ram Jet.
I would like to get some feedback, on thoughts and past projects others have completed before I dive headfirst into this one like I did my last swap.
Which entailed way to much $$$ and 3 years of fixing mistakes of parts.
The swap is from an 87 Firebird 2.8L, also any ideas on getting wiring harnesses for either motor
Old Feb 19, 2008 | 06:03 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
The Ram Jet uses the L31 shortblock. Cast pistons.
The Blueprint engine used hypereutectic pistons.
Neither cast nor hypereutectic recommended for power adder applications.
Old Feb 19, 2008 | 07:20 PM
kelham's Avatar
Re: New Project, v6-v8 Engine Combos
what type of piston would you recomend,,, i didnt know cast couldnt handle the power...? is that just with a large boost or would I be alright at lower boost... This will be a primarily street driven car
Old Feb 20, 2008 | 12:18 AM
five7kid's Avatar
In order of preference, forged, cast, and hypereutectic.
You might ask on the Power Adder forum. 12 psi doesn't sound really high, but it's probably worth going forged in case you want to go higher in the future.
Old Feb 20, 2008 | 05:41 AM
kelham's Avatar
k thanks
Blueprint makes a nice forged motor just expensive 6k, i could do it but would have to hold off on the supercharger for a while.
Old Feb 22, 2008 | 09:54 PM
KrisW's Avatar
Car: 88 V6 'bird/89TBI bird/85 T/A
Engine: 2.8/TBI/TPI
Transmission: V8 T-5/700R4 x2
Axle/Gears: 3.42 open/2.73 open/ 3.27 9 bolt
Also, do LOTS of measurements on that Ram Jet; I hear it doesn't fit under Firebird hoods well..
The Holley stealth ram will just fit and you have to cut some of the supports from the hood to do it...
I'm only pointing this out because when you list your car as "House of Colors Tangerine" it seems that maybe a hood swap was not anticipated...
Old Feb 24, 2008 | 11:16 PM
kelham's Avatar
thanks chris, the project is actually if different car than in my sig, that one is completed. I have the same thing with the other car though, painted before the engine and drivetrain were done so thanks. I think im going blueprint forged motor with arizona speed fuel injection.
Cleotiz
Jan 6, 2018 08:56 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
IMissMy86TA
Aug 31, 2015 08:40 PM
E Rod
Aug 28, 2015 05:17 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
