350 in for a 305
Old Mar 17, 2004 | 08:41 PM
jake_91_rs's Avatar
Car: 1991 RS Camaro
Transmission: 5sp
350 in for a 305
ok.....the tranny in my 305 has gone to ****.....so i've got the about 4500 to play w/.....i'm thinking about building a budget 383 stroker and puttin a th 400 behind it w/ a transbrake.....i'm wanting something w/ around 400 hp...something streetable enough to drive every day and still be dependable but something w/ enough hp to blow off the back tires! what do you guys think I could build a motor for price wise?
Old Mar 17, 2004 | 09:51 PM
TA5LiterHO's Avatar
Car: 1984 Trans Am WS6
Transmission: 700r4 Highly Modified
$4500 is plenty to build a 400hp engine. You could easily pull 400hp with a 350 also and be happy with the power. A 383 may run you a bit more money depending on what parts you use. If you want the car to be a daily driver I would use a built 700r4 with a good converter because of the overdrive.
xkingcodex
Feb 12, 2020 07:43 PM
Jake_92RS
Jan 28, 2020 10:37 PM
Dwayne614
Sep 28, 2015 08:33 AM
theurge
Aug 21, 2015 12:46 PM
st.evel07
Aug 13, 2015 06:15 PM
