base timing 35* BTDC
Old Mar 23, 2004 | 01:09 PM
icanoutfishyou's Avatar
Car: 1985 Camaro Z28
Engine: GM Goodwrench Crate 350
Transmission: 700 R 4
... I put in a crate GM Goodwrench 350; despite what everyone claims is a poor engine. Maybe a poor choice of judgement on my part.. anyways
Finally got the car running recently after intalling the engine late july of 2003.
parts list
Edelbrock performer 600cfm carb
Edelbrock performer intake
new HEI non cc distributor
New accel plug wires
New Fuel Pump and filter
I have purchased a timing advance timing light, and if I attempt to tune the timing at 800 rpm's to a reasonable 8* BTDC the engine bogs down and performs poorly. It seems to perform best at a base timing of 35* BTDC; with the vacuum advance hooked up it's running about 55* BTDC.
Any Ideas on the problem?
I've already checked the vacuum connections; all is well.
Old Mar 23, 2004 | 03:10 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Balancer slipped; or balancer and timing cover are not a matched set (balancer made for a 12:30 timing tab, timing cover has a 1:15 timing tab)
five7kid's Avatar
Transmission: 4L80E/4L80E
The timing tab and harmonic damper are mismatched.
I assume you reused your original damper, and the tab was on the engine. Look at the location of the tab on the old engine vs. the new.
Old Mar 23, 2004 | 03:12 PM
five7kid's Avatar
(Dang, RB beat me to it again! )
Old Mar 23, 2004 | 05:34 PM
Damn,
After all this fuss, I feel like a complete moron. I had purchased a new harmonic balancer; unfortunately it was one for a diesel engine... (sonofabitch.) I guess I automatically assumed that a 1985 caprice had a 350 with a 6 & 3/4 inch harmonic balancer; it must not be if my timing mark is that far off. The only question that I pose now is:
When I set the mark to TDC according to the tab (which is new with the crate engine...), both valves are closed on cylinder #1. . .
What should I do? Strip everything down and put a new balancer on it?
BTW I appreciate everyone's help, it's really helped me out!
Old Mar 23, 2004 | 05:38 PM
five7kid's Avatar
You need to determine #1 top dead center. One way is to remove the #1 spark plug and put in a "piston stop". Turn the engine over by hand until the piston "gently" comes up to the piston stop. Mark the damper at the "zero" of the tab.
Now turn the engine back the other way until #1 piston comes back up against the stop. Mark the damper again.
TDC is exactly half way between the two marks.
Or, tear it down and put the proper dampen on.
Old Mar 23, 2004 | 05:46 PM
alright, I'll have to try that this weekend;
I hardly every get time during the week to work on this thing, it's been the 'ongoing' weekend project.
I'll let everyone knows what happens if/when I get it going properly
Old Mar 23, 2004 | 11:19 PM
f-crazy's Avatar
Car: Bright Red 91 GTA
Engine: CARBED LT4
Transmission: MK6
Also when using the piston stop be very carefull on how far you screw the stop into the cylinder...i screwed mine in to far and hit it a little to hard and it bent the bolt...and it marred the spark plug threads trying to take it out..
You dont have to use a "TAB" when timing it in...use the stop to find TDC and make a stationary mark on the motor or whatever using white out or somthing to scratch the cover, then put the timing tape at that mark...
Old Mar 24, 2004 | 09:38 AM
f-crazy
I think i'm going to install the proper harmonic balancer. Couldn't damage result using an improper balancer?
Also a mechanic friend of mine has been toying around the idea that the cam gear is a tooth off or something (i'm not too knowledgeable about that stuff)
Old Mar 24, 2004 | 11:24 AM
scottland's Avatar
Car: '82 Z28
Engine: 350HO
Transmission: M4
also, might want to lower your idle a tad bit to set the timing, just to make sure that your setting the base timing without any advance. something like 650-700rpm is about right.
might be overkill, but atleast you know that the mechanical advance isn't doing anything.
thats not the problem now, but when you get the new balencer on, and find tdc, you get the timing accurate.
Vintageracer
Jan 10, 2020 05:33 PM
Andrew6.688
Dec 13, 2015 10:59 AM
bamaboy0323
Sep 3, 2015 06:07 AM
z28_AJ
Aug 27, 2015 08:59 PM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
