pulling engine question
Old Mar 31, 2004 | 10:27 PM
Z's r Best's Avatar
Car: '86 IROC, black and sharp
Engine: 305 tpi, bone stock
Axle/Gears: 3.42 pos w/rear db
Can you leave the transmission (700r4) bolted to the engine and pull both at the same time? Or will I have to unbolt the transmission and drop it out from the bottom? Since I'm planning on storing the old stuff in the building anyway I just figured it would be nice if I could pull it as a unit and then store it as a unit without the extra work of unbolting them and then bolting them back together. Thanks for the input.
Old Apr 1, 2004 | 12:34 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
I did it, but I wouldn't try it without a tilt sling.
Old Apr 1, 2004 | 12:39 PM
88IROC350TPI's Avatar
Car: '89 IROC-Z
Engine: Canfield 195 headed 358ci
Transmission: TH350, Art Carr 9.5"
Axle/Gears: 3.92 Dana 44
Thats probably the easiest way of doing it but you definately need a tilt sling thingiemabob. Make sure you drain the transmission or you're gonna have a crap load of trans fluid on the ground when you tilt the transmission back. Also make sure your radiator and everything is out of the way you really need that extra space to pull the motor forward and out.
Old Apr 2, 2004 | 04:38 AM
Z's r Best's Avatar
Thanks. I'll start disconnecting the hoses, wiring, draining the transmission and removing the radiator this weekend. Hopefully the engine hoist and stand will get here soon after.
Old Apr 2, 2004 | 06:07 AM
1986redbird's Avatar
I have pulled mine a couple of times for various reasons and never used a tilt sling, If you jack the back of the car up as far as you can and put jack stands under it you can pull the motor/tranny ALMOST level out of the engine compartment, IMHO it make the whole job much easier.
Old Apr 2, 2004 | 08:17 AM
five7kid's Avatar
There's certainly more than one way to skin a cat. Adjusting a tilt sling is easier and safer than jacking up and supporting half the car. And, small adjustments possible with the tilt during reinstallation can be very welcome.
But,whatever.
Old Apr 2, 2004 | 08:36 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
on the other hand,......
if you choose to separate the two, I found this to be so much easier than a cherry picker
Vintageracer
Jan 10, 2020 05:33 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
redmaroz
Aug 16, 2015 11:40 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
