help with a 5.7
Old Apr 4, 2004 | 03:48 PM
whitecamrs's Avatar
Car: camaro88RS
Engine: 2.8l
Transmission: 700-R4
help with a 5.7
I got a motor from a friend that was on a pick up deluxe 30 custom chevy 85 the motor has numbers on it...here is it
GM5.7LG , SGI ,and kind of a serial on it 14093638 on the block and 14102191 on teh heads.
So as u can see i want to figure out what kind of motor do i have the only thing i know is a 5.7L mark on it what else can u guys tell me
Old Apr 4, 2004 | 04:12 PM
ljnowell's Avatar
definately a 350, i think that one was made from 86-94 though, unless my sources are incorrect. The heads should be from an EFI engine (probably the original ones). THey have 1.94 1.50 valves.
Old Apr 4, 2004 | 04:24 PM
whitecamrs's Avatar
Car: camaro88RS
Engine: 2.8l
a 350 makes me very happy,also a have a 305 tpi from a 87 camaro it's the tpi interchangeble i mighty put the intake and all the parts on this 350.What do u guys suggest should i go for a carb or a TPI
Old Apr 4, 2004 | 05:20 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Yup, TPI will work, but you might have a hard time bolting it to those heads. The bolt pattern was slightly different.
blackz281le
Jan 11, 2016 07:51 AM
KO1
16
Oct 15, 2015 05:00 PM
LT1Formula
Oct 8, 2015 08:34 PM
usafirebird
Sep 29, 2015 11:58 PM
IROCtometal
Sep 9, 2015 10:01 AM
