LT1 fuse block ? quick!
Old Apr 13, 2004 | 09:33 PM
tamatt27's Avatar
Car: Kitt
Engine: Classified
Axle/Gears: Moser/4:11
Will I need this?
http://cgi.ebay.com/ebaymotors/ws/eB...sPageName=WDVW
Old Apr 13, 2004 | 10:39 PM
TexasLT1's Avatar
Car: '92 RS
Its not necessary but it would simplify the wiring in some respects because it would put everything in one place, but its going to be more work to add that along with everything else.
Old Apr 14, 2004 | 10:15 PM
tamatt27's Avatar
Car: Kitt
Engine: Classified
Does it look like the whole LT1 engine harness or just excess wires?
Old Apr 14, 2004 | 10:22 PM
TexasLT1's Avatar
Car: '92 RS
It looks to be the entire underhood chassis wiring harness. I don't see anything for the PCM harness in the photo, but its hard to tell.
*Edit* And upon further inspection, thats what it is listed as, "Item: Under Hood wire harness "
Old Apr 14, 2004 | 10:46 PM
tamatt27's Avatar
Car: Kitt
Engine: Classified
So ya think this will plug into the PCM?
Old Apr 14, 2004 | 10:51 PM
TexasLT1's Avatar
Car: '92 RS
I doubt its going to be a direct plug-and-play type of thing, but it shouldn't be too difficult to wire in just the fuse box with the PCM. I would get rid of all of the 4th gen chassis wiring.
Old Apr 14, 2004 | 11:04 PM
tamatt27's Avatar
Car: Kitt
Engine: Classified
Since I already have the LT1 PCM, would I need anything else major besides this harness to runt he LT1?
Old Apr 15, 2004 | 07:10 AM
TexasLT1's Avatar
Car: '92 RS
I'm not sure what you mean by this. Other than the fuel pump, powersteering lines, and fuel lines, sounds like you should be good.
Old Apr 15, 2004 | 11:57 AM
Thirim's Avatar
Car: 89 GTA
Engine: 350 LT1
i am doing my swap without the fuse box. To date. I have cut the connectors off for the fuse box, deleted 90% of those wires since most aren't needed. The only thing I neded to put a fuse on was the pcm, injector x2, + 1 other, pink power wires. I put an inline fuse on these. prob not needed, I did anyway. (1 fuse for all those wires).. Then I already had dual elec fans, so I used those wires and relays. These relays are the same as the MAF relays, so you will have 2 extras.. at least on my 89 TA
Old Apr 15, 2004 | 01:30 PM
TexasLT1's Avatar
Car: '92 RS
Which is exactly what I did too. The fuse box isn't necessary, it could just tidy things up a little bit.
Old Apr 15, 2004 | 07:57 PM
tamatt27's Avatar
Car: Kitt
Engine: Classified
Ok thanks. Sorry my question was a little misleading. I meant, the whole wiring harness that was listed on the auction....does it look like the engine harness? I meant will I need any other wiring to complete the swap as far as the engine goes? Also, the fuel pump. Will I have to switch my TBI pump to a TPI/LT1 one or could I just add another external fuel pump. Seems the tank's gonna be a bi#ch to get out... Does the TPI/LT1 FP just drop right in and plug in no problems?? Thanks a bunch. How's the site comin'? I haven't had a chance to check it out lately.
Old Apr 15, 2004 | 08:27 PM
Thirim's Avatar
Car: 89 GTA
Engine: 350 LT1
I swaped from a tpi so I didn't have to touch the fuel pump.. but if you have tbi I believe all you have to do is put on an inline fuel pump. so no need to drop tank. Verify that 'cause like I say I went from a tpi so I avoided that.
Old Apr 15, 2004 | 11:50 PM
TexasLT1's Avatar
Car: '92 RS
The ebay harness looks like everything EXCEPT the engine harness, its hard to tell though. You'll definitely need to change out the pump, or add an inline as you said. I went ahead and got a stock replacement TPI pump and changed it out. Really wasn't that bad.
I've got the transmission section up on the site, waiting for some photos I've got on the way to do cooling, a/c, and powersteering. After that is wiring, but it will be at least midweek before I can get back to work on it. Stupid research papers
Old Apr 16, 2004 | 04:58 AM
Thirim's Avatar
Car: 89 GTA
Engine: 350 LT1
i don't see any injector plugs or pcm connectors.. this probably isn't what you want.
Old Apr 16, 2004 | 04:59 AM
Thirim's Avatar
Car: 89 GTA
Engine: 350 LT1
i swapped from '89 305 TPI TA to a 96 LT1 using 94PCM.. I didn't use or need or want this.
Old Jun 14, 2014 | 08:55 PM
Iceship's Avatar
Re: LT1 fuse block ? quick!
Any of u have any pics of how you did your wiring...
Jorlain
Oct 8, 2015 01:57 AM
New2Chevy
Sep 28, 2015 12:35 AM
88 TA GTA
LSX and LTX Parts
Sep 11, 2015 11:31 PM
Vassago
Convertibles
Sep 4, 2015 09:37 PM
90formulaVortec
Sep 3, 2015 09:26 AM
