motor mount bracket
Old Apr 17, 2004 | 12:20 AM
84406's Avatar
Car: 84 Z28
Engine: 355/460hp
Transmission: glide\ford 9"
motor mount bracket
On all sbc's I have dealt with the motor mount bracket that attaches to the block have been the same. I have swapped in a 78 block into my 84 Z28 and at first used the brackets that were on it and they didn't fit right so I checked the originals off my 84 Z-28/305 and found they are different. On has the thru bolt hole about 1\2" closer to the block and the other is the same as all chevy brackets. I have been having a problem with my hooker LT's and found swapping the brackets does change where the motor sits. Is that the way the 3rd gen's were with two different brackets? If that is the way they should be which side does the short one go on as I didn't check when I took them off.
Old Apr 17, 2004 | 02:37 PM
84406's Avatar
Car: 84 Z28
Engine: 355/460hp
Out of 29418 members I thought maybe someone would have run across this one way or the other. Any suggestions on who might have that info on the net?
Old Feb 2, 2006 | 06:53 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Axle/Gears: 3.08 10 Bolt
im having the same problem and need an answer...
Old Feb 2, 2006 | 07:01 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
https://www.thirdgen.org/techbb2/sho...hreadid=293412
Old Feb 2, 2006 | 10:00 PM
1320_Guy's Avatar
Car: 89 RS
Transmission: th350
I ordered mine from sdpc (look near the botom of the link posted in the other post) and i have had no probs with them. I got em within a week if i remember right.
One bracket did come gloss black and the other primer grey tho. Dident realy matter to me cant realy c them anyways
ZMWojnar
Brakes
May 12, 2019 10:43 PM
E Rod
Aug 28, 2015 05:17 AM
Elliswon
Aug 10, 2015 12:33 PM
NBrehm
Aug 5, 2015 07:57 PM
