LS1 Numbers: 373.5 HP / 430.1 TQ @5200 rpm
done in 4th gear
1st RUN
373.4 HOP
429.9 TQ
4th gear, 126 mph
2nd RUN
373.5 HP
430.1 TQ
4th gear, 134 mph
A little lower then i had hoped......Considering it's measured at the wheels, I can't complain....
Gotta get over 400 HP.....:lala:
1st RUN
373.4 HOP
429.9 TQ
4th gear, 126 mph
2nd RUN
373.5 HP
430.1 TQ
4th gear, 134 mph
Car: 89 camaro RS
Engine: soon to be juiced built 357
Transmission: turbo 350
Damn dude you car is friggin awesome...I wish I had an LS-1/t56 but I guess I will have to settle for a LT-1/auto in my future trans am
....Man I bow down to your car literally...its badass:hail: :hail: :hail: CONGRATS MAN!
....Man I bow down to your car literally...its badass:hail: :hail: :hail: CONGRATS MAN! Supreme Member
Car: 89 RS
Transmission: TH350
Sweet.
Now lets get to the track, lol.
With my TR224 cam, I'm hoping for 325 RWHP at least. I'm getting closer. Cant wait either.
Edit: Whats up with only 5200 RPM's?
Now lets get to the track, lol.With my TR224 cam, I'm hoping for 325 RWHP at least. I'm getting closer. Cant wait either.
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
I thought you went with the stock heads and cam in that thing. What combo did you end up going with to get those numbers. Your car must fly. Did you use custom headers?
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
Those numbers were with the 75 HP nitrous jets
yea, Z28***** is correct, those are with the 75 HP jets
Without the nitrous, at the flywheel I got.......
365.8 HP, that's with the custom exhaust and custom intake, about 40 hp over stock....
Also if it matters i used the 19" wheels.....someone mentioned with smaller tires you can get better numbers, but i'm not sure.....
Originally posted by nolanr0413
sweet, next get that car to a track and get some 1/4 miles times.
If might have to wait until i get out to California and do a couple of more things to the engine.......(loose weight & ignition)
Car: 88 IROC
great numbers!
NOW MAKE A VIDEO DAMMIT!!!(*@&(@
don't have the graph in front of me now, but it was around 310 at the wheels without the nitrous.....
Internship in Pasadena for 14 weeks......The LS1 will meet it's match with a 2,800 road trip......
stock LS1's peak at about 5200 rpm so nothing out of the ordinary there. Although NX guarantees within 2% of their advertised hp ratings at the wheels so If you made 310 NA and 373 on nitrous I think you should contact NX about that. Roy did a good job. Also, what's up with the flywheel #'s if you didn't have it put on an engine dyno?
Car: 84Z/ 87 S-10
Engine: 355/350
Transmission: th-350/700-r4
you can calculates flywheel numbers using rwhp i got a calcualter that i dl'd for free that does it a long with calculating et form hp/weight, getting cid and hp rating, its kinda like desk top dyno but free
Car: 90 Iroc
Engine: 383LS1
Axle/Gears: 4.10
FLYNLOW92rs,
Man I was all impressed untill I saw you were running no2. j/k Those are very strong numbers. What rear end are you using and did you have all the belts on during the pull? Do worry about converting to flywheel HP because most of the LS1 guys use the HP at the wheels (RWHP).
StngKlr,
I can't wait to see your numbers with that cam. I am guessing in the 360+rwhp range with a good tune. I was looking at the same cam from thuner racing untill another setup poped up.
Both of you guys are driving me hard to get my car done. The only problem is my funds are running low because I set my goals a little high and needed a few other things for the LS1.
BTW My goal is to go hunting for Z06's and viper's. besides my Stealth already screams for a daily driver so I atleast have to my the Iroc faster than it is.
Good luck with the projects!!
StngKlr,
Car: 89 RS
Transmission: TH350
I think the only time that I will get a Dyno is when it gets tuned also. Most of my testing will be on the track, since there is one 5 mins. away from my house. Its only an 1/8th, but Ennis (Texas Motorplex) is a good 2 hour drive from here. My ultimate goal is 11's N/A, but thats some time and $$ away.
FLYNLOW - Your PM's are full.
FLYNLOW92rs, Those are very strong numbers. What rear end are you using and did you have all the belts on during the pull?
PM's are cleaned out, good luck with the hunting for R1's......A viper was advertised as 500 HP, 500 TQ, so they aren't that far off numbers wise, but getting that power to the ground in a thirdgen might require some work.....
Car: 90 Iroc
Engine: 383LS1
Axle/Gears: 4.10
Posi Disc 3.42 rear out of a 1999 SS
Car: Malibu 80, T/A 87, S-15 87
Engine: 267 Bu, 305 T/A, 350 S-15
Transmission: Auto Bu, 5spd T/A, Auto S-15
Nice #
I'd say low 12's... very low, huggin the 11's.
Do you have some meat to hook?
a Viper? No idea whats there ET.
dbrochard
Sep 19, 2015 08:13 PM
MikkoV
Sep 9, 2015 04:25 PM
