lt1 headers
Old Apr 29, 2004 | 09:43 PM
ionicswing's Avatar
lt1 headers
srry if this is a repeat question, but......will aftermarket headers.......say hooker headers........fit in a third gen, with no modifications??
Old Apr 29, 2004 | 09:44 PM
pasky's Avatar
Car: 1991 RS Camaro (Jet Black)
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
Any headers that fit a thirdgen 350 will fit a lt1 and clear
Old Apr 29, 2004 | 09:49 PM
StealthElephant's Avatar
Car: 87' Iroc
Will they line up with the Ypipe as well? I would think there would be some change.
Old Apr 29, 2004 | 10:29 PM
pasky's Avatar
My SLP headers for a thirdgen and Y-pipe line up fine.
Old Apr 29, 2004 | 11:16 PM
TexasLT1's Avatar
Car: '92 RS
ANY thirdgen header will work. nothing is different about the exhaust ports between the LT1 and a Gen 1 SBC
Old Apr 30, 2004 | 01:28 AM
pasky's Avatar
Well, I think the LT1 exhaust ports are "D" shaped, only thing different I can think of.
Old Apr 30, 2004 | 07:29 AM
TexasLT1's Avatar
Car: '92 RS
Yeah, I meant as far as spacing and all that crap like the LS1.
Old Apr 30, 2004 | 02:39 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Any 3rdgen header will bolt onto an LT1.
Old Apr 30, 2004 | 04:23 PM
z_power's Avatar
Car: '89 GTA
Engine: a bunch of pieces
Transmission: still there - very stockish TH700
Do you know if 1 5/8 primaries will be enough to cover D-ports? I'm goin' to order Hedman LT 's from ACS (68460); some say "weld/grind and it fits ok" but I wouldn't like to modify 'em because of coating.
Old Apr 30, 2004 | 04:32 PM
pasky's Avatar
My SLP's are 1 5/8", believe TexasLT1's are hedman 1 5/8". Mine fit up fine, some people say you may need to grind the lip a little on the headers first.
Old Apr 30, 2004 | 04:39 PM
z_power's Avatar
Car: '89 GTA
Little grinding on the inside of port opening shouldn't hurt to much, I think; thanks pasky
Old Apr 30, 2004 | 06:01 PM
TexasLT1's Avatar
Car: '92 RS
Yup, mine are 1-5/8". Probably wouldnt hurt to do a little grinding on the pipes, but they've been fine so far.
TX-SleeperC5
Feb 24, 2016 01:34 PM
L0tuS
Oct 4, 2015 08:07 AM
jerflash
Sep 24, 2015 03:11 PM
mygta87
Sep 14, 2015 10:36 PM
L0tuS
Sep 4, 2015 11:16 PM
