2.8 V6 CAMARO to LT1 Carbed
Old May 11, 2004 | 09:47 PM
FastKitteN's Avatar
Car: 1988 Camaro
Engine: 5.7liter v8 (LT1 carb)
Transmission: th-350 rebuilt with a 2400-2800 stall
Anyone done this? went from the v6 to the lt1 carbed? I'm in the process of doing this and I almost have all the parts together. If any has have you had any problems? I'm going with a th-350 transmission that is be rebuilt. I have all aftermarket Autometer Phantom gauges. Please let me know of any troubles I about ready to pull the old out and in with this beast. Would I have to change drive shafts thats one im not sure of.
thanks for any heads up.
Old May 11, 2004 | 10:15 PM
br()bert's Avatar
Car: 85 firebird
Engine: Pos 2.8 pulled and replaced with a 350 tpi motor converted to carb.
Transmission: 700r4, vette servo,shift kit, hayden 15"x8" trans cooler.
Im doing a fi v6 to carbed v8 swap but mine isnt an lt1. Same difference though. I dont think you'll have to change the drive shaft. I know i dont, i could be wrong though. But hey, have fun!
btw from what everyone says getting the old motor mounts off is one of the hardest parts.
Old May 11, 2004 | 10:27 PM
AutoX86Z28's Avatar
Car: 86 Camaro
Engine: none
Transmission: none
Axle/Gears: GT4, 3:73s
i just cut the head of the bolt and POOF the mounts fell off. but getting them on was a different story
Old May 12, 2004 | 07:45 AM
TexasLT1's Avatar
Car: '92 RS
There is someone else who has done it but I can't remember their name. Going to a carb greatly simplifies the whole swap, but if you want a/c you're still going to have to notch the frame. With a TH350 I think you'll need to a longer driveshaft. If that becomes a problem let me know, my brother had a custom one made in Houston for his car for I think $100 that was supposed to be good to over 500hp. I think. I'll check with him about it. Also, you'll either want to get a very good fuel pressure regulator, or get a fuel pump designed for a carb. Other than that, I don't think you'll have too much trouble doing the swap.
Old May 13, 2004 | 01:17 PM
Twilightoptics's Avatar
Car: '87 IROC-Z/'82 RX7
Engine: SBC 355/1.1L Rotary
Transmission: T56/5 Speed
Axle/Gears: 4.33/3.93
The TH350 has to have a 9" tailshaft, or you'll need the longer 200r4 driveshaft, or lengthen yours for like $65 at a driveline shop.
Old May 14, 2004 | 09:33 PM
Riley's35089rs+'s Avatar
Car: 89rs (previous 2.8)
Engine: 406
Transmission: 700r4 (for now)
should be a direct bolt in with the 9" shaft ...the 6 inch gives you the problem.
oops thats what you just said eh twilight!
Old May 15, 2004 | 11:45 AM
FastKitteN's Avatar
Car: 1988 Camaro
Do you guys know if a 2nd gen drive shaft would work? My friend who gave me the tranny has a few of them. He said it works with the tranny?
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Zane Story
Oct 8, 2015 12:40 PM
usafirebird
Sep 29, 2015 11:58 PM
skinny z
Carburetors
Sep 29, 2015 11:25 PM
rjcme
Sep 5, 2015 01:23 PM
