95 LT1 w/ 92 700r4
Old May 12, 2004 | 02:41 PM
mess21's Avatar
95 LT1 w/ 92 700r4
i'm goin to be dropin in a LT1 into my 92 camaro. will the LT1 bolt up to my 700r4 in the car now??? i think it will but what do i have to do to make it work. and is it worth it or should i just trough a 4l60e in it. eventually either one i go with will be rebuilt. also is the LT1/4L60e a direct fit lenght wise in other words can i use the stock drive shaft etc
Old May 14, 2004 | 11:53 PM
LT1guy's Avatar
Car: 1987 Trans Am
Driveshaft length is the same with either tranny. If you want to use a Th700R4 behind your LT1 instead of a 4L60E, you'll need to use a 93 throttle body since it has the provisions for the TV cable. 94-up used the 4L60E so the linkage is different. Id use the 700 myself. esp if you already have it and don't have a 4L60E. You shouldn't have to change anything else.
Old May 15, 2004 | 05:23 AM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
Also need to use a 93 TV cable, and make the VSS work properly.
Old May 15, 2004 | 05:48 PM
mess21's Avatar
what is "VSS" i think its vehical speed sensor right or wrong?? and also if i stay wit the 700r4 which i probally will do i need the VSS out of the donor car or what?
Old May 15, 2004 | 09:00 PM
LT1guy's Avatar
Car: 1987 Trans Am
I'm not positive, but since your third gen is a later one I would bet the stock VSS (vehicle speed sensor, yes) is compatible. If you already have a TPI TV cable it might work, otherwise the 93 one (or one from Street&Performance or Lokar) would be the one to get.
Old May 16, 2004 | 03:25 AM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
The pulse on the thirdgen one and 4th gen one are nowhere near the same, it will not work for him, neither will a tpi tv cable, a 93 piece is what is needed.
Old May 20, 2004 | 12:56 AM
adonwayne@aol.c's Avatar
Car: 92 formula conv.
Engine: LT1 355 FI
95 LT1 w/ 92 700r4
I have done the swap LT1 in a 92 firebird,the 700r4 will work but it won't last long if it's stock it won't take the H.P. & torque. I went to a B&M 700r4 trany after i trashed the stock unit.
Old Jun 15, 2004 | 07:36 PM
loweredd's Avatar
Car: 84 Silverado
Was the kickdown set correctly? These were stock with a 700R4.
L0tuS
Oct 4, 2015 08:07 AM
C409
Sep 1, 2015 03:42 PM
Jax86SC
Mar 21, 2002 01:15 PM
Iroc87
Mar 2, 2002 08:03 PM
