400 crank in a 350
Old Jun 7, 2004 | 10:56 PM
Charged350's Avatar
Car: 87 IROC Z28
Engine: Custom Forged 355
Axle/Gears: 9" 4:11's Detroit Locker
400 crank in a 350
im puttin one in, what will be the cubes with a 5.7 rod....
Old Jun 7, 2004 | 11:05 PM
LilJayV10's Avatar
Car: 89' T/A, 00' Firehawk
Engine: 406 Roller
Transmission: TH700R4 w/2800 stall
Axle/Gears: 3.23 Posi
It will be a 383 if you bore the engine .030 over. You can't just put a 400 crank into a 350, it has to be machined. You can get aftermarket 383 cranks pretty cheap now, depending on what you are wanting to do with the engine, it may be better to go aftermarket.
Jason
Old Jun 8, 2004 | 12:43 AM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Don't put a 400 crank in a 350 its just not a good idea. It weakens the crank and will cost more to have it machined, then an aftermarket piece. Look for a 3.75" crank setup for 350 mains, commonly know as a 383 crank.
Old Jun 9, 2004 | 07:13 PM
Charged350's Avatar
Car: 87 IROC Z28
two people told me it iwll fit, i havent tried it yet, but this weekend we shall give it a shot, my cuz did it to one of his motors b4, so i uess he knows wha hes doin, im stuck with this crank for now, later on ill build a blower motor for a procharger so this is just for now, its cranking about 450 right now, just not enough....
Old Jun 9, 2004 | 09:24 PM
Flyte risk's Avatar
Car: 85 IROC
Engine: tree-oh-five
Transmission: 700, but the T-56 is laying on the floor
How exactly will it weaken the crank?
Old Jun 10, 2004 | 07:13 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
2 people were wrong.
It won't fit. The main journal diameter is different.
You will have to machine the mains down, and then it can fit.
350 rods and pistons will not fit when used with a 400 crank. The pistons will stick out the top of the block. However you can hang the 350 pistons on 400 rods, and then they will fit. After you get the crank turned down of course.
Even if three or more people come along and tell you what you want to hear, the reality will not change.
Old Jun 10, 2004 | 08:21 AM
Thirim's Avatar
Car: 89 GTA
Engine: 350 LT1
don't u also hav eto get the block machined to have a bit lipped off the bottom of the cyl, to allow for the crank to spin free?
Old Jun 10, 2004 | 09:52 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Sometimes. Depends on the block.
Old Jun 10, 2004 | 09:28 PM
Charged350's Avatar
Car: 87 IROC Z28
we shall see what kinda cam it is this weekend, i havent seen the thing yet, but i heard that i cna shave my gm crank .060 under....is this true, cuz i can do that and get oversized bearings then....
Old Jun 10, 2004 | 10:17 PM
ljnowell's Avatar
.060?? Never heard of going that far in my life.
Old Jun 10, 2004 | 10:18 PM
ljnowell's Avatar
course maybe to fit a 350 block, i dont know. seems like a lot of machine work when you could just get a 383 crank.
Old Jun 13, 2004 | 07:20 PM
Charged350's Avatar
Car: 87 IROC Z28
mex, got a 350 crank, its in, just gotta trow that tranny back in, i need a converter for it,....hmm..anyone got one..
Old Jun 13, 2004 | 08:58 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
What happened with the 400 crank?
Old Jun 14, 2004 | 06:28 PM
Charged350's Avatar
Car: 87 IROC Z28
nothing, my cuz got a punch in da face for tellin me its a 400 when it was a 350...he plays to much, now hes hurtin....hahh
mddaniel
Sep 8, 2015 05:16 PM
camaro71633
Sep 1, 2015 10:24 AM
downsouthboy
Aug 29, 2015 11:29 AM
Eric-86sc
Aug 24, 2015 09:01 PM
