2.8 to 4.3 swap questions???
Old Jun 20, 2004 | 08:56 AM
Wincil->>>'s Avatar
Car: 1987 Pontiac firebird
Engine: 3.1 liter
First is it hard or even possible, and what do you senior members think about 4.3 liter engines are they reliable and easily hot hot rodded. Any help at all will be appreciated.
Old Jun 20, 2004 | 03:25 PM
flyitlikustolit's Avatar
Car: 1982 Trans Am
Engine: 383 chevy
Axle/Gears: 4th gen 10-bolt, posi, 3.42 ratio
they're good engines, and I think they're very reliable. what you need to do though, is try looking for speed parts for a 4.3 . I had an s10 truck i was going to hop up, until i realizews that there is a serious lack of speed parts. hot rod did a junkyard jewel one month and got over 300 hp, and about 400 ft lbs, if IIRC. so reliable, yes, feasible, maybe, would I do it? no. I'd hold out for two more cylinders, and get a 350 or something else. (a 4.3 is a 350 missing two cylinders).
Old Jun 20, 2004 | 04:27 PM
THEGENERAL's Avatar
Car: 1966 impala , 1998 sebring vert,1978 buick regal turbo, 1991 chevy silverado 3/4ton 4x4 lifted
Engine: 283, 2.5,3.8 turbo 350
Transmission: powerglide,auto overdrive, th350,4L80
It would cost as much to swap in the 4.3 as it would a 350, why not just do that? It would also be easier to make power that way.
Old Jun 20, 2004 | 11:06 PM
Wincil->>>'s Avatar
Engine: 3.1 liter
I had a blazer with a good 4.3 in it an it ran great and got really good gas mileage. the gas mileage has been a main focus. cant decide if it is worth it
Old Jun 22, 2004 | 11:42 PM
Wincil->>>'s Avatar
Engine: 3.1 liter
If i put the 4.3 in i would be able to swap to a 350 or higher at any time cause they fit the same as far as i know and if i do swap to a 4.3 what will be the best moves (considering money ) to hot rod it.
Old Jun 23, 2004 | 02:40 AM
Car: 1982 Trans Am
Engine: 383 chevy
you're looking at a tough selection for hot rod parts. most manifolds (in performance apps...) are limited to custom jobs. there are some performance manifolds out there, but selection is highly limted, just like a for a 60 degree v-6, only not as bad, because the 4.3 v6 has the same bore and storke as a 350. so 350 rods and pistons work in a 4.3 (262 cid). BUT. the valves don't get much bigger, and a wild cam is non-existent. but there are some decent cams in jeg's and other places, and with some work to the heads, you can make upwards of 300 hp. forced induction is gonna be a custom job only, though, and nitrous is gonna be your best bet for any serious horsepower. your weakness with any high horsepower is gonna be the crank. you can use 350 rods and pistons, but the crank is unique to that engine. I'd recommend mapping out what you wanna do, and looking for the hop-up parts. if there's enough of those lying around that you can buy/beg/steal, go for it. it'd definitely be different. (i'd still rather do a 350 swap). and yes, you can always drop in a 350, especially if you don't mess up the mount holes in the k-member. good luck.
Old Jun 23, 2004 | 11:15 AM
ede's Avatar
ede
the crank is weak for preformance, good heads can be had from GMPP. lot of 350 parts work. it isn't a simple swap and a 350 could be had easier and for the same cost, or less.
Old Jun 23, 2004 | 01:25 PM
Wincil->>>'s Avatar
Engine: 3.1 liter
now im habing second thoughts about which motor to go with, i like the 350 but everyone has it. i wanna have some different
Cleotiz
Jan 6, 2018 08:56 PM
E Rod
Aug 28, 2015 05:17 AM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
reiderz iroc
Aug 13, 2015 04:57 PM
