short block vs. long block vs. complete?
Old Jun 24, 2004 | 10:53 AM
Diabolical's Avatar
Car: 85 Trans Am WS6
Engine: 305HO L69
what is the difference between a short block, and long block, and a complete motor? what is included in each?
Old Jun 24, 2004 | 11:06 AM
Spectre's Avatar
Car: Camaro Z281991 Engine: 5.7L/350 TPI Transmission: TH700R4 ··································· Car: Acura CL 1998
Engine: 3.0L/183
Transmission: 4 spd auto/OD
Short block is a block with rotating assembly (pistons/rods/crank) and camshaft
Long block is a short block with cilynder heads (some with the Intake)
Complete is the long block with injection, and accessories.
Old Jun 24, 2004 | 03:30 PM
ljnowell's Avatar
I sometimes see short blocks without cam and timing set also.
Old Jun 24, 2004 | 04:55 PM
f-crazy's Avatar
Car: Bright Red 91 GTA
Engine: CARBED LT4
Transmission: MK6
thats becasue a real shortblock doesnt have a cam and timing set..only the rotating assembly
the long block has the cam, timing set and heads...
that doesnt mean that companies couldnt do what they wanted
Old Jun 24, 2004 | 06:38 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
A shortblock typically does not include the cam. Hard to keep those lifter in without heads, rockers, pushrods (factory roller excepted).
Longblock typically includes tin but no manifolds. Sometimes includes balancer & flexplate, sometimes water pump, usually not, though.
But, these really are terms defined more by the user than by convention. So, make sure you know what you're paying for before handing over the plastic.
Old Jun 28, 2004 | 02:28 PM
Diabolical's Avatar
Engine: 305HO L69
actually, i am selling a motor that i was building. as of now, it has the rotating assembly, cam and lifters in it. i have stock heads that i could bolt on, but i don't have an intake that would bolt on. i also have vortec heads that i was going to use on the motor. i have an intake manifold for, but i would need to get longer pushrods for it. i also have an oil pan, timing cover and balancer, but no waterpump or flexplate.
Terrell351
Jun 13, 2021 01:13 PM
Casey Meyers
Mar 2, 2016 10:46 AM
MoJoe
Sep 24, 2015 09:12 PM
KO1
Aug 31, 2015 06:31 PM
BlackphantomZ28
Aug 22, 2015 01:00 PM
