Can LT4 springs handle the lift of a C305 and 1.6 RR's?
Old Jun 24, 2004 | 04:40 PM
pasky's Avatar
Car: 1991 RS Camaro (Jet Black)
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
I posted this on another forum but hopefully the LT1 guru's here can have some input here:
Yes I know its better to get other springs but I have some lt4 springs sitting in the garage. Can they handle the lift or am I forced to buy some beefier springs? If so can someone recommend some valve springs that will use the stock seats? Thanks.
Old Jun 24, 2004 | 07:39 PM
pasky's Avatar
Ok, answer is no, too much lift. Anyone know any aftermarket valve springs that can handle the lift of a C305 with 1.6 Roller rockers and still use the stock spring seats? I don't want to pull the heads yet. Thanks.
Old Jun 25, 2004 | 10:10 AM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
I take it you checked out over on www.camaroz28.com. There are a lot of guys running that cam on untouched heads. They should shed some light.
Old Jun 25, 2004 | 05:06 PM
J's T/A's Avatar
Car: 82 Trans Am
Engine: LTX
Axle/Gears: 3.42 strengthed 7.5 inch
go to CZ28.com and check out combination motorsports they sell springs that fit the stock pockets but will handle cams with alot more lift than the CC305
Old Jun 25, 2004 | 05:07 PM
pasky's Avatar
Kickass. May be doing the cam swap in about 4 weeks .
Old Jun 25, 2004 | 05:11 PM
J's T/A's Avatar
Car: 82 Trans Am
Engine: LTX
forgot to add they sell complete cam swap kits for the LT1 with springs, retainers and rockers..
Old Jun 25, 2004 | 05:12 PM
pasky's Avatar
I'll definatley be checking it out.
Old Jun 26, 2004 | 04:48 PM
TexasLT1's Avatar
Car: '92 RS
Whats the lift of the 305 with 1.6's? I'm using stock LT4 cams with the Hotcam and 1.6 rockers and its right at the "max" lift for the springs.
Old Jun 26, 2004 | 08:33 PM
pasky's Avatar
I believe its .540 unless comp cams rates thier cams using 1.6, if thats the case then its .510. Im positive I can't use the lt4 springs. But I don't want to pull the heads and have new seats made.
Old Jun 27, 2004 | 09:31 AM
J's T/A's Avatar
Car: 82 Trans Am
Engine: LTX
comp rates their cams with 1.5 rockers..
Old Jun 27, 2004 | 12:04 PM
Thirim's Avatar
Car: 89 GTA
Engine: 350 LT1
what kind of performance increase does an LT4 Cam give you?
Old Jun 27, 2004 | 03:01 PM
J's T/A's Avatar
Car: 82 Trans Am
Engine: LTX
Usually The LT4 cam and heads swap will give you somewhere in the range of 340-350 rwhp..
the cam swap alone will give you 320-330rwhp.. head to the LT1 section of cz28.com and search for LT4 Dyno results that should give you an idea of the ballpark, save for a few freakish posts..
Old Jun 27, 2004 | 03:27 PM
pasky's Avatar
Just scored a C306 .
Old Jun 27, 2004 | 03:29 PM
J's T/A's Avatar
Car: 82 Trans Am
Engine: LTX
Your in TX, go score some heads from Lloyd now, tell him Julian sent ya..
Old Jun 27, 2004 | 03:39 PM
TexasLT1's Avatar
Car: '92 RS
Sweeeeet. My best friend did a CC306 and ported LT1 head swap on his car. He pulls me by a length on the highway, but I'll get him everytime out of the hole.
Old Jun 27, 2004 | 03:42 PM
pasky's Avatar
Im taking it one step at a time man .
Old Jun 28, 2004 | 10:04 PM
tamatt27's Avatar
Car: Kitt
Engine: Classified
Axle/Gears: Moser/4:11
Now....tell me where you saw the deal on the CC305, so I can get it.
Old Jun 28, 2004 | 10:30 PM
pasky's Avatar
It got sold, reason why I got a CC 306 . Check the classifieds on Camaroz28.com. Tons of big cams going fairly cheap.
Old Jun 30, 2004 | 03:10 PM
pasky's Avatar
Just picked up a set of springs, locks, and retainers from combination motorsports that can handle up to .600 lift using the stock lt1 spring seats. Only $121 shipped to my door. Spoke with Brian, great company and thanks for the referral.
Old Jun 30, 2004 | 10:06 PM
J's T/A's Avatar
Car: 82 Trans Am
Engine: LTX
Not a problem, anything to make a thirdgen a little faster..
working on gears now!
87v6Bird
Jul 1, 2018 04:12 PM
13sec83trans
Carburetors
22
Nov 28, 2015 09:26 PM
Jorlain
Oct 8, 2015 01:57 AM
tommy z-28
Oct 6, 2015 10:58 PM
sandman92084
Sep 12, 2015 10:27 PM
